  • Dot Guests: 320
Author Topic: Combination switch/blinkers  (Read 27606 times)
Offline stanley
« on: February 03, 2017, 09:52:05 AM »
Hey guys im having trouble with my blinkers. The hazards come on whenever i turn the blikers on (left or right). But it seems to stop doing it on really hot days..?? Anyone know how i can fix it? Cheers
Offline stanley
Re: Combination switch/blinkers
« Reply #1 on: February 03, 2017, 09:55:24 AM »
Im trying to post a photo of the combination switch because its not the original, pretty sure its from an old jeep? Wont let me post because the photo is over 800kb
« Reply #2 on: February 03, 2017, 03:11:49 PM »
to post the photo, reduce it's size in say paint... or there is a program that lets you do it automatically (photobucket rings a bell)..... as for the wiring... hmmm. check the hazard switch as well that there are no wires shorting out...all the indicators wires go through this switch as well....
« Reply #3 on: February 05, 2017, 04:25:59 PM »
Check your earth is good too
Offline Hobbit
« Reply #4 on: February 05, 2017, 07:12:37 PM »
Nothing should work if it was the earth. The hot weather thing makes this question a real mystery. Condensation? Corrosion? ??? If the switch is not original, it sounds like a wiring mix-up or it's not plugged in / joined correctly. You'll have to check the circuit.
Offline LS120
« Reply #5 on: March 21, 2017, 05:22:52 PM »
it could also be the hazard switch playing up..
Offline smithy
  • first Bedford CF Van 1984
« Reply #6 on: March 26, 2017, 01:59:25 PM »
I just sorted my electrical problem I hope by changing the fuse box for one I tested before all good now to fix cactus one
Bedford, Beer, or B###s
