  • Dot Guests: 365
Author Topic: Celica 5 speed conversion  (Read 11148 times)
Re: Celica 5 speed conversion
« Reply #10 on: May 01, 2009, 10:55:07 PM »
Sorry Marky ment to get some pics for ya, will do tomorrow....I run hydrolic master and slave cylinders, rod Hadfields bell housing,  dyna truck clutch set up of some sort,  custom cross member and hangers bolted through Chassis. works well but as you mentioned my shifter at the mo is not Quite, but almost in the back of the van ;D......working on a remote shifter (with everything else)....ps it's a supra box not a celica so, not sure on the Celica measurements??? hope this helps....
Offline Marky
« Reply #11 on: May 02, 2009, 02:09:19 PM »
Heres some photos of the box and the Gear Linkage..
Creative Media Producer
« Reply #12 on: May 03, 2009, 09:58:21 PM »
i think you will find from talking to the bloke i bought it off..
all you need is a tie rod end socket mounted to the floor to mount the gear shifter too and it sould all work properly.. its just like an extension of the gear knob.. apparently works fantastic once it setup also..
Offline Atoyer
« Reply #13 on: May 31, 2009, 01:09:06 PM »
Hey,
Although I'm having proplems with the clutch cable at moment I have the supra 5 speed conversion in my beddie
So, if any pics are still needed or you near Melbourne and want to have a look for yourself let me know and i post some up for you.
Tonz
Offline ethyl
« Reply #14 on: May 31, 2009, 09:01:09 PM »
as a variation to this I am fitting a Tarago 5 spd behind an injected blue 202
this is same box as Supra but diff front and rear housings, rear mount is on top and is round bush type (haven't worked out crossmember yet but shouldn't be hard to suspend from chassis)
best part is the shifter, remote teleflex cables so can put it right forward in Beddy position and run cables back to the 2 levers on the side of the box
« Reply #15 on: May 31, 2009, 11:57:02 PM »
sorry Marky ....long time over due ::) hope these help
Offline Marky
« Reply #16 on: June 02, 2009, 12:58:00 PM »
Thanks Dano :)
aka5000
« Reply #17 on: August 14, 2009, 10:24:23 AM »
Hey all I'm after a speedo cable to suit the Celica 4 spd I just chucked in my van, any ideas before I go looking through yellow pages?
Alex
« Reply #18 on: August 14, 2009, 01:07:54 PM »
Where abouts are you? I have lots of speedo cables for the Celica boxes.
Offline neville668bartos
« Reply #19 on: August 14, 2009, 02:04:07 PM »
the rod shop do a celica 4 to holden speedo cable. from memory it was bout $70
