  • Dot Guests: 217
Author Topic: bedford wheel studs  (Read 5539 times)
Offline john
bedford wheel studs
« on: April 15, 2009, 07:55:06 PM »
hi there, i,m after a couple of bedford van stock wheel studs and 1 zoose fastner, the screw type thing that holds engine hood down, i will mail you a prepaid satchel addressed to me if you can help. my phone no is 08 93447721 perth metro ask for john, thanks.
hammers_spanners
Re: bedford wheel studs
« Reply #1 on: April 15, 2009, 08:09:00 PM »
Gday John which studs are you needing. SWB or LWB r/h or l/h. Also do you have a picutre of the fastener?
Craig
« Reply #2 on: April 15, 2009, 08:23:27 PM »
Gidday John if you can't find any studs closer I have some spares (in Qld) to suit a swb (with nuts) you can have.
good luck with the zoose fastener as I think by memory there was a previous thread on buga looking for one of those to no avail!
Offline john
« Reply #3 on: April 25, 2009, 10:30:49 PM »
hi hot rod, thanks for the reply, dont need the nuts just studs,can you give an address so i can post you satchel to return studs. or contact   triker@iprimus.com.au or ph 08 93447721  many thanks john.
Offline Worzel
« Reply #4 on: April 26, 2009, 10:45:30 AM »
