  • Dot Guests: 217
Author Topic: twin thermo wiring  (Read 4258 times)
Offline maria
twin thermo wiring
« on: April 06, 2009, 07:38:15 PM »
hi,
not sure if there's already infor about this on here,but, i've got a new triple core radiator and have added an extra thermo fan. one wasn't enough. so now i have two fan's worth of wiring to attach to the single plugs from the old setup. can i just thread the wires from the two fans together or is this suicidal?
any info appreciated
thanks
maria
hammers_spanners
Re: twin thermo wiring
« Reply #1 on: April 06, 2009, 07:46:05 PM »
Maria that shouldn't be a problem as long as you get the polarity of the wires right! You will also need to make sure the new fan is mounted correctly to blow through or draw through air over the radiator.
Give me a call.
Craig
« Reply #2 on: April 06, 2009, 07:55:10 PM »
You'll also need to make sure the wiring is up to the task of supplying current to both fans.
« Reply #3 on: April 06, 2009, 11:19:34 PM »
My advice is to:
- run each fan off a seperate relay.
- use heavy cable.
- put a thermal circuit breaker in the circuit.
If one fan siezes, (which they do occasionaly) you can pull the relay out and keep going on the other fan.
I got caught once.
I use a couple of relay holders and a thermal circuit breaker out of an XF Falcon. You will find them in the engine bay on the drivers side inner guard.
Chris
Offline maria
« Reply #4 on: April 07, 2009, 12:03:28 AM »
okay thanks all. will be getting some help with this, not going hell for leather on my own. that would be terrifying. love my beautiful new radiator! it's so shiny.
« Reply #5 on: April 07, 2009, 05:15:54 PM »
Come on Maria...Show us a pic of your new radiator :o :o ;D ;D :D cheers...johnno
Offline maria
« Reply #6 on: April 07, 2009, 07:45:57 PM »
I'll upload it tomorrow night when i have a second to sit down (i'm standing up right now). i've made it a little less shiny trying to get it in. sure is a squeeze.
