  • Dot Guests: 264
Author Topic: Diff Ratio's  (Read 13701 times)
bunger64
Re: Diff Ratio's
« Reply #10 on: April 14, 2009, 05:41:27 PM »
I used a L J  torana booster and a xb falcon master that was modified for disc at brake shop i changed booster as it is supposed to be better boost WITH V8 CONVERSION
Re: Diff Ratio's
« Reply #11 on: April 14, 2009, 07:23:25 PM »
Hi bunger I measured my 94 ef v8 fairmont diff & I recon I need 25 or 30mm spacers on each side then I can fit standard falcon wheels of about 7 or 8 inches wide no probs Cheers Reid
bunger64
Re: Diff Ratio's
« Reply #12 on: April 14, 2009, 09:06:32 PM »
Don't know about that diff but the diff i use is out of a AU Falcon  because its wider
