  • Dot Guests: 144
Author Topic: front end rubber  (Read 9047 times)
Offline phill
front end rubber
« on: September 07, 2017, 07:08:19 PM »
Hi all
trying to find front end rubber
I'm after coil spring insulators the ones that are in between spring and lower wishbone
wishbone bump stops and the ones that are in between crossmember and chaise locating bracket
 called pedders, no luck, wondering if there is another type that will fit the bedford sett up
Phil
Offline LS120
Re: front end rubber
« Reply #1 on: September 07, 2017, 07:59:27 PM »
the coil springs one i think the Holden one fit.. as for insulators (cross member ones) i have not seen them.. i was lucky to have a good set on mine.. may be a piece of 10-mm neoprene with the holes drilled in it will be OK?? as it's just a shock insulator.
Offline Zeeman
« Reply #2 on: September 07, 2017, 09:58:59 PM »
The closest I found for upper bump stop rubbers were Nolathane universal  47173
Lower bump stop rubbers Nolathane universal 47043 with the top modified
Can't get lower coil spring insulator, plastic hose generally works fine.
Crossmember to body rubbers aren't made as far as I am aware, perhaps Rob at Bedford Manor could supply a second hand pair.
Offline phill
« Reply #3 on: September 09, 2017, 10:31:00 AM »
Cheers LS120 and Zeeman
Talked to Rob at Bedford Manor and hes got the crossmember ones
Zeeman those nolathane bump stops look pretty cool and I had a look at the commodore donner car, rear coil ones and they fit ok so im thinking of using them
Phil
Offline Zeeman
« Reply #4 on: September 09, 2017, 02:43:25 PM »
Yes, I believe the ones I used are Holden ones, also sold as universal ones. I was also told VN wagon bump stops would also work? If you need any other bushes, Superpro make all the suspension arm ones, upper and lower.
If you notice in the picture above, I also made an upper coil spring insulator machined from nolathane, I got a bit carried away when rebuilding my front end!
« Last Edit: September 09, 2017, 02:47:10 PM by Zeeman »
Offline phill
« Reply #5 on: September 09, 2017, 04:11:07 PM »
 I thought it was odd that there was no upper one
Also was wondering what what yellow thing was in your pic
Nice work
Phil
Offline Catcher
« Reply #6 on: September 11, 2017, 10:35:10 AM »
Zeeman that front end looks the bees knees. Ive just pulled my front end out. Its got cracks in the upper arm and one of the upper arm bolts is seized. Ive got  long way to get it there but thanks for the inspiration.
Catcher
Catcher
« Reply #7 on: September 11, 2017, 10:54:07 AM »
We had cracks in ours too when we restored ours,  Ray welded them up,
Offline Zeeman
« Reply #8 on: September 11, 2017, 11:58:53 AM »
Thanks Catcher, fair bit of work to get it there. Started out repairing a dodgy weld, ended up stripping the whole thing for drop spindles, new disc brakes, and Transit power steering conversion.
I got a good second hand set of suspension arms from Bedford Manor, as mine had been chromed and were in poor condition.
« Last Edit: September 11, 2017, 12:00:49 PM by Zeeman »
Offline Garlini
« Reply #9 on: September 24, 2017, 03:54:10 AM »
sorry, I think you're looking at this
I do not know if I put the link well
https://bedford-ersatzteile.de/index.php?a=445&lang=eng
