  • Dot Guests: 270
Author Topic: Advise on raising the rear end of a CF350 Motorhome. About 3.5T  (Read 22758 times)
Offline Stevo
Its not that I mind the power steering effect of a heavy motorhome body on the back of the CF-350.
But I'd like to even up the heavy assed profile a bit. I was thinking of fabricating longer rear spring hangers or airbags on top of the rear springs. But surely that would just raise the front the same height because the weight distribution is still the same?
All ideas appreciated. Looks like it needs a 3"  lift. How would one go about this? :o
Offline Zeeman
Re: Advise on raising the rear end of a CF350 Motorhome. About 3.5T
« Reply #1 on: June 29, 2017, 09:25:43 AM »
Get your leaf springs reset to the desired height, any decent spring place should be able to do it.
Offline johnxb351
« Reply #2 on: August 09, 2024, 08:17:08 AM »
 Did you ever raise the rear of your  cf 350  . if what did you do
