  • Dot Guests: 219
Author Topic: Fuel Pup and filter  (Read 25451 times)
Fuel Pup and filter
« on: April 20, 2017, 01:30:30 PM »
Hi I have a VN-VP Holden motor in my Bedford Van, I need to renew the fuel Pump and Filter, but not sure what has been used (photos attached) looks like a (EFI VK Fuel Pump, mount and Dampers) which would make it a 3.3 L , the current setup seems to work ok, as far as supplying fuel goes, also looks like it has a regulator of some kind attached as well, I think it is still the standard Bedford Tank as you can see in the photos it has two pipes from the tank, so I guess one is a return, so the Bedford tank may have been modified to some degree. Does anyone know what this pump etc is out of, Holden for sure.. Or any ideas what I could replace it with that would suit the VN Motor. Thanks….
Offline phill
Re: Fuel Pup and filter
« Reply #1 on: April 20, 2017, 02:01:25 PM »
Hi Baz
I'm not sure what pump you have fitted but if you have a look on the v6 conversions site they recommend what pump to use and give you part numbers
Phil
« Reply #2 on: April 20, 2017, 02:07:54 PM »
Thanks /   v6 conversions site ? / OK found it - thanks.....
« Last Edit: April 20, 2017, 02:12:30 PM by Bas / NZ »
Offline phill
« Reply #3 on: April 20, 2017, 02:14:41 PM »
Phil
