  • Dot Guests: 145
Author Topic: Bedford CF Parts  (Read 23376 times)
Offline Kennedy
  • probationary
Bedford CF Parts
« on: March 08, 2017, 12:30:26 PM »
Hi, I am looking for a master cylinder for a GM Bedford CF 1977. Please contact Dale if you have one. 0425 223 008
Offline Stevo
Re: Bedford CF Parts
« Reply #1 on: March 27, 2017, 10:05:46 PM »
Good luck with that Dale. I've had my one in getting recoed, Resleived etc. My CF1 76 is a CF350 with the reservoir that is bolted down with 4 bolts. Its a 3/4". The Brake place is having a second go at it after I couldn't bleed the fronts up in the vice... The piston is a two piece affair and there is a tiny pin that holds them together. Apparently the brake dude used to bigger pin and it caused the piston to stick in.
These were available for a very limited time in the UK as I understand.
After a bit of googling I noticed the Triumph Stagg, 2500pi, TC2000 that came out with a 7/8" master looks identical apart from the diameter. So if this guy can't fix it I think I'll take a look at the Triumph option.
« Last Edit: March 27, 2017, 10:13:00 PM by Stevo »
Offline Bedford Fever
« Reply #2 on: March 29, 2017, 07:57:58 PM »
  That brake fluid plastic resevor looks nasty . I am sure you will find one , but it does pay to have
  it reconditioned for your sanity . I got mine reco from a place in Melbourne called Vac Air Services
  (03) 9464-2122 . That was about 6 years ago and cost approx $260.00 .
  All the best in your quest to stop that Beddy safely
 Cheers Frank
Offline Stevo
« Reply #3 on: March 29, 2017, 10:34:03 PM »
You can buy new reservoirs from Rimmers in the UK. A new lockheed 7/8s Master and reservoir is $200 plus freight or a twr one is $143 plus freight also from Rimmers.
