  • Dot Guests: 369
Author Topic: Noobie.. CF2 AmboCamper Rear axle question..  (Read 13370 times)
Offline Steve366
« on: February 13, 2017, 03:51:29 PM »
Hi All,  new to this CF business.  I have the std front hubs (5 stud) but the rear has a PCD of around 181mm(7.1inch) with 6 studs. Any Idea what this rear end is? Need to locate some better wheels...  !!
Offline greasey monkey
Re: Noobie.. CF2 AmboCamper Rear axle question..
« Reply #1 on: February 18, 2017, 09:13:34 AM »
hi there Steve,
that seems a fair bit weird as i also have a CF2 Ambo, n have a five stud bedford axle under the rear of mine which is the standard 5x150 pcd but it sounds like someone has fitted 6Stud bedford diff which is 6x180mm most likely would of happened when the original diff gave up
 the later model ford transit rims are the same PCD if your looking for some sort of rim to fit
hope that helps
Scott
Offline Steve366
« Reply #2 on: February 18, 2017, 02:31:03 PM »
Yeah ...  no one can identify  for certain but looks like a light truck rear end.  It makes a nasty noise as it is!   Might consider options for another set up.
