  • Dot Guests: 329
Author Topic: Diff Info  (Read 27385 times)
Offline SandB
Re: Diff Info
« Reply #30 on: March 16, 2009, 10:46:43 PM »
Thanks Worzel for your coments!! As I said t Craig, the van is a 100 ks from here, so I am relying on whatever the Mechanic says!! If it was here; I'd be doing the job myself.
Here; I'd be doing a transplant--   We just need t get it back home for as cheap as possible!!
Will have serious talks with every Beddie owner at the Nats----------------if we get there????
Cheers Brian
" BEDDIED AT LAST!!"
Re: Diff Info
« Reply #31 on: March 16, 2009, 11:10:42 PM »
cool look fwd to meeting you and will help as much as possible. ;D ;D
Re: Diff Info
« Reply #32 on: March 17, 2009, 07:17:40 PM »
hey Worzel. I had an original beddie 'heavy duty' diff under the camper but unfortunatelty turfed it, it came with a larger diff housing and had 10" drums instead of the norm 8" drums on single wheel axles. I think I got that right coz it was about 4 years ago when I lifted it out and remember it being much heavier and bulkier then the standard size beddie diff, all the mounting brackets and such were original factory made, it was high speed from memory and I swapped it for a 9" then put it under the donor van and then sold the lot to somewhere in the Dandenongs
Offline SandB
Re: Diff Info
« Reply #33 on: March 17, 2009, 07:36:42 PM »
At last some "good news", A very old gentleman here in Pirie has his own CF camper van and a wrecked Beddie in his backyard. He has given me a complete diff; so worst case cenario is t tro it in and hope it takes us t Beddie Heaven-----ie The Nats!!!
Cheers Brian--------- ::) is that a smile I see there??
P.S.   Thanks for all the help and advice!!!!!
Re: Diff Info
« Reply #34 on: March 17, 2009, 08:07:08 PM »
Fingers and toes crossed for you Brian....I hope it all works well for ya.... ;D cheers...johnno
Re: Diff Info
« Reply #35 on: March 17, 2009, 08:51:02 PM »
good on you brian. ;D
Offline Worzel
Re: Diff Info
« Reply #36 on: March 18, 2009, 11:19:20 AM »
well there ya go. Learning all the time
sounds like you'd be unlucky to have one cause parts would be a sh1t :-\
Offline Marky
Re: Diff Info
« Reply #37 on: March 18, 2009, 01:19:54 PM »
just pulled apart my borg warner diff
and was well surprised?!
it has redrilled splines that fit hq stud pattern...with beddy wheel bearings ..n lockheed wheel cylinders n pads
nothing is ever standard on a beddy ???
Creative Media Producer
Offline SandB
Re: Diff Info
« Reply #38 on: March 18, 2009, 05:40:25 PM »
Hey Peoples< The Saga continues!!!!  Got my new (second/diff) home t/day (walked it home on a sacktruck)  Here we go again, the one in the van is a 21 spline and of course the one I got t/day is a 25 spline------ Major learning curve happening here!!!
Correct me if I'm wrong!  G diff  8/37 ratio    should be 25 spline axle??????
                                    F diff  7/37 ratio     should be 21 spline axle?????
So what I'm gonna do is thro the complete diff   Rust and all, under the old girl (not Carole) t get her home!!!
If anyone has a 21 spline axle for sale, I could be interested, unless I go the Holden salisbury diff way!!
I am confused but "learning"
Cheers Brian O :-[
