  • Dot Guests: 317
Author Topic: Toyota 5sp box  (Read 34985 times)
Offline Glenn
Toyota 5sp box
« on: November 28, 2016, 02:23:58 PM »
Hi guys first time here need some help. I have cf camper 202 motor with auto. Going to go with w50 5speed box. Wondering about what clutch to put in or will only one type fit. Camper is full back on it with bed over cab so a bit of weight in it. Is there a heavyweight clutch I can use. Any help would be gr8
Offline Marky
Re: Toyota 5sp box
« Reply #1 on: November 28, 2016, 02:49:04 PM »
Hi glenn
ive run 5 peed boxes in all my bedfords
theres two types of clutches avail from memory...a normal and a heavy duty
i always used the normal in my CFL...dont quote me..but thinks it was a toyota dyna clutch..
Creative Media Producer
Offline Glenn
Re: Toyota 5sp box
« Reply #2 on: November 28, 2016, 05:10:18 PM »
Thanks for that I will look in to that cheers
Offline Hobbit
Re: Toyota 5sp box
« Reply #3 on: November 29, 2016, 12:17:55 AM »
G'day Glenn. welcome to BUGA.
I'm not much of mechanic but suggest you would need a Holden one tonner flywheel and pressure plate and a clutch plate with the Toyota spline. Excedy and other manufacturers do a heavy duty clutch kit. PBR or RPM would have a clutch to suit.
Cheers, Jeff.
Offline Glenn
Re: Toyota 5sp box
« Reply #4 on: November 29, 2016, 10:44:07 AM »
Cheers Jeff
Offline Glenn
Re: Toyota 5sp box
« Reply #5 on: November 30, 2016, 10:43:47 AM »
trying to find a clutch pedel  would any one no if there is different one i could use with out to menu mods
