  • Dot Guests: 303
Author Topic: diff ratio on my beddy  (Read 45600 times)
Offline Paulo
« on: November 27, 2016, 07:39:24 AM »
Hi there oh mighty bedford community, I have removed my diff and tried to work out the ratio, borg warner , when I checked the rotation of the wheels to the tail shaft flange I roughly 2.2 to 1 is this then a very low ratio diff  can someone please let me know if this is correct . thank you in advance
« Last Edit: November 27, 2016, 07:50:45 AM by Paulo »
Re: diff ratio on my beddy
« Reply #1 on: November 27, 2016, 08:59:28 AM »
If you only rotated the wheel once....no..... Rotate it TWICE (once for each sides wheel rotation) to get a 4.4:1 (or 4.454:1, which was an option)
Hope this helps...
Russell
Offline Paulo
« Reply #2 on: November 28, 2016, 08:55:10 PM »
Hi Russell
 thanks Russell so in the greater scheme is this diff going to rev the engine higher. or will it keep the rpm lower at 100 kph on the highway,
cheers Paulo
« Last Edit: November 28, 2016, 09:21:43 PM by Paulo »
« Reply #3 on: November 30, 2016, 07:41:46 PM »
the lower the numeric ratio, the lower the revs for any given speed.
Have a play with http://www.apexgarage.com/tech/gear_ratios.shtml to get some answers....
I am not endorsing this page (etc etc), just a random google find!
Offline Paulo
« Reply #4 on: December 03, 2016, 08:05:42 AM »
thanks mate I will
 Paul
