  • Dot Guests: 225
Author Topic: HQ disk brake conversion wanted  (Read 9498 times)
« on: August 13, 2016, 08:52:52 PM »
Wanted
Holden HQ Disk brake conversion for CF
Full setup or just caliper brackets
Cheers marty
Offline shaginwagin
  • Real Vans are BIG Vans
Re: HQ disk brake conversion wanted
« Reply #1 on: August 13, 2016, 10:03:51 PM »
Hi Marishka,  I have just gone all vn.   I can send you a pattern for the hq calipre bracket, its made out of  either 10 or 12 mm steel plate.
Julian
« Reply #2 on: August 14, 2016, 12:57:39 AM »
G/day Shaginwagin ,
That would be cool in case i cant locate a setup.
Offline shaginwagin
« Reply #3 on: August 14, 2016, 04:11:53 PM »
Hi Marishka,  can you send pm with your address, so I can send a template.   These pics will help with how it all goes together.  12mm plate. a few new bolts and spacers.  This plate is for PBR calipres.  What master cyl are you going to use.  I used a HQ, but I  a couple of years ago I went and bought a new HQ master cyl and it was, and the bowl was a bit higher and ity hit the bonnet,  so back to old one. now have VN, on it.
Julian
Offline shaginwagin
« Reply #4 on: August 14, 2016, 04:18:12 PM »
having trouble pic size to big all 811 to 820 kb. any suggestions how to post
Julian
Offline shaginwagin
« Reply #5 on: August 14, 2016, 04:24:26 PM »
here is pic of plate, the plate on the left is HQ the one on the right is vn 1st run.
Julian
Offline Marky
« Reply #6 on: August 15, 2016, 02:13:29 PM »
Hey Marty
I used a LJ torana booster w a XC falcon master
Need to widen holes in firewall a little..
But clears bonnet n stops like beast
Creative Media Producer
« Reply #7 on: August 16, 2016, 06:47:28 PM »
Cheers for the info guys.
Marty
Offline shaginwagin
« Reply #8 on: August 20, 2016, 11:16:50 AM »
Hi Marty,   have those templates arrive yet..??
Julian.
Julian
« Reply #9 on: August 20, 2016, 11:31:11 AM »
Hi Julian,
They came late yesterday in post.
Thanx heaps for that.
Cheers marty
