  • Dot Guests: 337
Author Topic: indicators stopped workinh  (Read 15850 times)
Offline Marky
« on: June 17, 2016, 09:49:38 AM »
hey all
lost indicators......
there is power to indicator stalk( horn works..HB..LB..dipper)
but no power at indicator wires
there is power at flasher unit and hazard flasher....
any ideas...? where to look
much appreciated
Creative Media Producer
Re: indicators stopped workinh
« Reply #1 on: June 17, 2016, 11:11:28 AM »
Do your hazards work ?
Offline Marky
« Reply #2 on: June 17, 2016, 12:53:05 PM »
No
Offline LS120
« Reply #3 on: June 17, 2016, 06:19:09 PM »
sound like flasher unit
Offline Marky
« Reply #4 on: June 17, 2016, 07:06:55 PM »
Power at flasher... Swapped w another spare...
No difference..
« Reply #5 on: June 17, 2016, 08:13:43 PM »
Do the indicator lights come on n stay on if you join the 2 wires that connect to the flasher unit?
Your spare flasher unit might be shot as well?
Offline JOE RYAN
« Reply #6 on: June 18, 2016, 09:29:22 AM »
I had a similar problem turned out to be a poor connection in the plug where the wiring harness passed through the firewall on the drivers side up near the top of the inner guard.
I had a multimeter and had 12 V at the indicator light but still would not work the resistance in the connector allowed the voltage to register at nil current but once a bulb tried to illuminate the resistance in the connector prevented sufficient current to pass.
Simple solution was to disconnect the plug and clean/brighten up the pins on the connector and all good
Joe
Offline Marky
« Reply #7 on: June 18, 2016, 12:10:48 PM »
thnx Joe ...will try that...
what colour was the wire thru the fire wall?
Offline LS120
« Reply #8 on: June 18, 2016, 06:19:28 PM »
if you have a 12v bulb you can test at the flasher, just put 1 wire from bulb to flasher out and other from bulb other lug to earth and it should flash if flasher works ok
Offline LS120
« Reply #9 on: June 18, 2016, 06:20:51 PM »
it could also be the indicator switch on the steering column..
