  • Dot Guests: 322
Author Topic: My Power Steering Install  (Read 35389 times)
Offline Chucky
Re: My Power Steering Install
« Reply #20 on: July 10, 2016, 09:29:57 PM »
I just checked my invoice and it lists the following:
P917R:  Rack End Eunos, Ford, Mazda
TE5361: Rodeo Tie Rod End
As for the other comments on my intermediate shaft, yes a new one could be fabricated, should I do this? No, because my legitimate engineer has passed it, should you? ask your engineer and do what they say.  Some engineers will pass mine, some wouldn't, some states would, some states wouldn't, I don't make those calls and neither do most of the people on here ;-)
now with that said and done, I took her for a good run today and the lock is a lot less but man it drives nice  :D
« Reply #21 on: July 11, 2016, 09:30:33 AM »
why has the lock changed ?
Offline phill
« Reply #22 on: July 11, 2016, 06:03:16 PM »
Thanks Chucky for the info
I will be talking to the engineer I'll be using soon, another thing on the list to play with
Phil
« Reply #23 on: July 12, 2016, 05:41:21 AM »
The lock changes because of the different pivot points and travel of the rack
Offline Bean
« Reply #24 on: July 16, 2016, 08:01:15 PM »
I have heard that there is a steering column that has an electric power steering unit all in one. I think the guys said its from a Hyundi of sorts - Does any one have any experience in this department? ,I recently had air con fitted, really good job, -Minus  1 degree C at the vent but the guy who did it reckons power steering isn't going to happen due to the limited space under there,He suggested the electric solution.
« Reply #25 on: July 19, 2016, 02:14:15 PM »
i've heard of a few people using astra or mazda 2 electric steering columns, haven't had first hand experience though.
Offline Chucky
« Reply #26 on: August 10, 2016, 03:32:20 PM »
I chose not to do the power assisted column, because I wanted a nice clean cab.  It is an option though, even with the original rack but a bit too bulky a solution for me.
I did another 400km trip on the weekend, absolutely no problems I'm finally happy and ready to fit my sway bar now :-)
« Reply #27 on: August 10, 2016, 03:44:05 PM »
you got an pics you can put up of your install ?
Offline Chucky
« Reply #28 on: November 05, 2016, 11:42:45 AM »
I'm not on here that often but I will try to post pics sometime soon.
