  • Dot Guests: 360
Author Topic: CFS Diff Gears/Highway Gears  (Read 16832 times)
Offline Drifter
    • my beddy resto
Re: CFS Diff Gears/Highway Gears
« Reply #10 on: June 21, 2016, 01:45:11 PM »
Bed767   -  what did you do with your rims to compensate for the shorter length...
never to old
Offline john
« Reply #11 on: June 21, 2016, 08:25:45 PM »
bedford swb diff housing measures 1568mm flange to flange and 1728 drum to drum face.  10 bolt salisbury housing measures 1455 flange to flange and 1560 drum to drum face or 1540 if disc brake. not a good option really. better to use vs commodore 1455 flange to flange, but they run a short 722mm   axle and long 820 mm axle so you cut short side and extend to run 2 long axles and hq offset rims to give same bedford tracking. spring saddles and shocker brackets welded to same as bedford and larger id u bolts, brake line fitting metric to imperial other little bits and pieces but thats basically it
Offline bed767
« Reply #12 on: June 21, 2016, 08:40:41 PM »
I run standard 15x10" mags with standard 3.75" holden offset with 275/60r15 tyres. This combination gives clearance of the tyres on the inside of the guards and puts the van rear in Bedford track.
Offline Drifter
    • my beddy resto
« Reply #13 on: June 22, 2016, 07:53:09 AM »
thanks fellas,  greatly appreciated...
never to old
