  • Dot Guests: 255
Author Topic: upper control arm rebound bush  (Read 5271 times)
Offline johng
  • im running down a dream !!
« on: January 24, 2016, 05:29:31 PM »
G day All
I am chasing up a few front end parts
Upper arm rebound bushes
Front spring insulators
& any info on fitting transit power steer rack of a 98/99 model tragedy van. does any one have a diagram of the plate they have used with dimensions ? & how they adapted the tie rod ends to suit the bedford steering arms of the stub axle
Also can the rubber control arm bushes still be bought i have nolathane in there at present but not keen on them !!
thanks all for your help
Re: upper control arm rebound bush
« Reply #1 on: January 25, 2016, 08:16:10 AM »
Hey John, have a look in my gallery ( page 6 ) i think, i have pics of my rack there and the simple mounting bracket we made up. I also upgraded the tie rod ends, i had some beefier ones machined up. The bracket was 10mm x 60mm flat bar from memory.
« Last Edit: January 25, 2016, 08:18:28 AM by Bedfordcrazy »
« Reply #2 on: January 25, 2016, 08:40:31 PM »
But George, have you tested the rack out yet...
« Reply #3 on: January 26, 2016, 08:16:58 AM »
sadly no, we did all the checks while it was in the air, but yep until it is on the road we cant do any fine tuning.
