  • Dot Guests: 333
Author Topic: Front Spring Insulator  (Read 4272 times)
Offline Sundownernz
« on: November 17, 2015, 03:33:22 PM »
Hi all,
Does anyone know where to get either the rubber or urethane front spring insulator that sits between the bottom of the front spring and the lower suspension arm. These are pretty much unobtainable in NZ so thought you Aussie buggas might know where in Aussie they can be obtained. Be great if it's around the Sydney area as I'm over there week after next so can pick them up. The last ones I got were from Pedders in Auckland but they have since closed down.
Cheers in advance,
Garry.
Offline VanWolf
Re: Front Spring Insulator
« Reply #1 on: November 18, 2015, 06:35:42 AM »
Garry,
Mine were OK but I did notice that the Commodore VN that I wrecked did have similar rubbers in the rear spring housings. Do you have any sizes as an indication?
Offline LS120
« Reply #2 on: November 20, 2015, 05:40:45 PM »
are they the triangle ones or the round ones the springs sit on.
David
Offline Sundownernz
« Reply #3 on: November 25, 2015, 09:15:35 AM »
The one the spring sits on. The other one is the bump stop.
