  • Dot Guests: 363
Author Topic: WRECKING MY VS COMMODORE UTE.....  (Read 16265 times)
Re: WRECKING MY VS COMMODORE UTE.....
« Reply #10 on: February 19, 2016, 09:22:38 AM »
going v6 now...do I keep the wire loom on the right the one with all the fuses....
« Reply #11 on: February 22, 2016, 05:36:59 AM »
Use the complete commodore loom, headlights to tail lights, might as well swap the petrol tanks as well and you'll have no problems.
« Reply #12 on: February 26, 2016, 07:57:29 PM »
bugger only kept the right side with the computer..kept the fuses ...
Offline shaginwagin
  • Real Vans are BIG Vans
« Reply #13 on: February 27, 2016, 06:04:21 PM »
Hi,  don't get rid of anything. Have transplanted vn v6 motor, gearbox, both radiator and air con radiator  full wiring harness, brake booster / master cyl,  disc brakes, instrument cluster, even fuel tank ,door handles and am working around central locking, aircon, and electric windows and mirrors all from vn donor car.  Just needs a little planning but all fits.
Julian
« Reply #14 on: February 28, 2016, 04:16:26 PM »
was told I can get right side from v6 conversions
Offline shaginwagin
« Reply #15 on: February 28, 2016, 04:46:06 PM »
Hi,   Does this mean you have already got rid of the donar car,   :(
Julian
« Reply #16 on: February 28, 2016, 04:48:09 PM »
YES,,,did you want anything
Offline shaginwagin
« Reply #17 on: February 28, 2016, 04:52:44 PM »
No but its easier to do the transplant if you still had the car.  Any bits you need its easy to get off the car than trying to get them from the wreckers.
Julian
« Reply #18 on: February 28, 2016, 04:54:49 PM »
kept everything I need..i hope.
engine.gearbox..tailshaft.diff cross member
radiator hoses.fan.........see how we go
Offline shaginwagin
« Reply #19 on: February 28, 2016, 05:00:45 PM »
When I did the beddie, I had a spare front axle, had the engine on the engine hoist sat in in the position i wanted it, and made the engine mounts up to what I wanted and then had them made up proffessionally fabricated.  Took a while but was able to fit the a/con compressor on the same engine mount as original.   Had to get a much longer fan belt but it all fits.
Julian
