  • Dot Guests: 382
Author Topic: CGW (Cut Grind Weld) Yet Another Diff Story.  (Read 5087 times)
Offline Man Of Steel
  • One Day Rodger Phips.... One Day
« on: February 12, 2009, 07:20:14 PM »
And So It begins.......   I thought I had scored, Two Salsbury LSD diffs for the price of one, one buggered one not.  All good so far. Turns out the buggered one with a couple of teeth chipped on the pinion is a 3.55 and that was the ratio i wanted. So i opened up the other one and ye gods its a 4.44  Ah well at least i have all the bits to GCW a wide one. So if any one in NZ wants a 4.44 Salsbury LSD head I have one to trade for a 3.55 unless you have a 3.08.
Tune in next week for the next exciting episode  of CGW.... MWA HAHAHAHA
I Can Too.... Down Hill With A Tail Wind.
Offline waikatostocky
Re: CGW (Cut Grind Weld) Yet Another Diff Story.
« Reply #1 on: February 12, 2009, 09:16:17 PM »
Hay man of steel a mate of mine in Otorohuga may have a 3.08 head. If he has i will see what he wants for it and if you want it i am going to Bleniam on the 23rd of this mounth i could drop it off for you.
Cheers Paddy ;D
be safe out there
Bren
« Reply #2 on: February 17, 2009, 03:37:39 PM »
well i need a 4.44 centre but not in NZ.....
« Reply #3 on: February 20, 2009, 06:12:19 PM »
Paddy that sounds great but....  Im outa town till the 27th.... would be nice to know what he wants for it though... then we could work out how to get hold of it .
MOS
« Reply #4 on: February 20, 2009, 06:15:55 PM »
Bren .... are they hard to get? if you like i could check out how much to get it over the ditch. It will only end up as a door stop or in the scrap bin.... we are getting $200 a tonne for steel.
MOS
« Reply #5 on: February 21, 2009, 03:30:51 PM »
he has used his one in a ute he is building but i found this one on trademe
http://www.trademe.co.nz/Trade-Me-Motors/Car-parts-accessories/Holden/Diffs-axles/auction-203276841.htm
sorry about that thought i could help.
be safe out there
Bren
« Reply #6 on: February 23, 2009, 09:55:33 AM »
They are not too hard to get, but they are getting rarer, and they are easy to blow up...... whack it on ebay or trademe, you might get someone looking for it.
I think the 4.44LSD only came out on 6 cyl manual HQ utes.... autos and v8's had 2.78's and 3.08's (although i could be wrong)
Since they are the lowest ratio you can get for a sals diff they are perfect for cheaper end of drag cars...
