  • Dot Guests: 202
Author Topic: What's your camper weigh..  (Read 3951 times)
« on: February 12, 2009, 04:59:29 PM »
ok guys i just put my 83 cf camper over the scales and just about died..
What does the campers out there weigh??  ???
my camper eas 2.44 tone with 75ltr water, awning, gen, etc... but no people in it at the time.. only cost $5.00 for the print out docket.
so whats yours weigh?
Offline Clance
    • My Home Page
Re: What's your camper weigh..
« Reply #1 on: February 14, 2009, 09:21:10 AM »
Mine scared me too!! 5.83T loaded without people
« Reply #2 on: February 18, 2009, 02:41:43 PM »
what are the laws about taking out the front center radiator brace & making it a bolt on , bolt off part?? as would make removing the motor alot better.
as far as i know it is not a major structur of the van/truck.
anyone know??
« Reply #3 on: February 18, 2009, 05:07:54 PM »
I think the Series 2 beddies (square nose) have that set up, someone correct me if I'm wrong
« Reply #4 on: February 18, 2009, 06:29:12 PM »
Warren you are correct, if you do this in the Mk 1 you need to brace each side with 2inch x 3ml flat steel runners. (for WOF reasons)
I did this on mine before I changed it to a Mk 2 front, this old photo shows the bolt holes the steel was bolted too. ( this passed WOF)
« Last Edit: February 18, 2009, 06:46:08 PM by Bas NZ »
« Reply #5 on: February 18, 2009, 06:50:08 PM »
Hay, I'm no longer a Gumbie, but now I'm full of bog, I don't no what one is better.
doofhard
« Reply #6 on: February 18, 2009, 07:43:00 PM »
Don't worry I know what i'm full of ;D
« Reply #7 on: February 19, 2009, 04:51:29 AM »
thanks Bas NZ.
looks like what i want to do... saves taking the body so high in removing the motor.
the brace steel goes behind the front bolt holes either side?? & was it welded in or not. ??
thanks
« Reply #8 on: February 19, 2009, 09:13:26 AM »
So do we, and its all soft a squishy  ;D
