  • Dot Guests: 335
Author Topic: CF 250 speedometer  (Read 9962 times)
Offline backshedman
CF 250 speedometer
« on: July 10, 2015, 03:02:24 PM »
finally got a cable made for my speedo, fitted it ... and now the speedo bumped between speeds for a while then died altogether. i think i need a new speedometer. Anyone?
ambience
Re: CF 250 speedometer
« Reply #1 on: July 10, 2015, 05:54:14 PM »
If the speedo is "jumping" it is generally the cable not running smoothly. Check that there are no "tight" bends or is the outer cable isn't kinked?
Before you replace the speedo/gauges, check that the cable is seated in the speedo properly.... like is the odometer changing? If yes, check the cable is turning. If again yes....you need a new speedo.
Offline backshedman
« Reply #2 on: July 12, 2015, 10:31:42 PM »
thanks for that ... I'll double check
ambience
Offline backshedman
« Reply #3 on: July 13, 2015, 09:46:19 AM »
i am an idiot .... mis typed ... should be 280P
ambience
Offline backshedman
« Reply #4 on: July 13, 2015, 09:47:01 AM »
I am an idiot ... should be 280P  :o
ambience
Offline VanWolf
« Reply #5 on: July 13, 2015, 03:14:49 PM »
Also you could try squirting some oil down inside the cable to make sure it is lubricated.
Offline backshedman
« Reply #6 on: November 05, 2015, 09:38:06 AM »
thanks for the tips everybody
ambience
