  • Dot Guests: 359
Author Topic: help - wheel and tyres  (Read 11593 times)
Offline KT
Re: help - wheel and tyres
« Reply #10 on: June 20, 2015, 07:23:42 AM »
Not too sure about the adaptors, someone with more experience /knowledge could answer that.
I run a 5mm universal aluminium spacers, with multi holes for different stud patterns between the axle and the inside of the wheel to widen the overall rear track.
Busy, I'm trying to locate a  complete working heater assembly for a 1977 CF 250 SWB, can you help ?
Offline Bean
« Reply #11 on: June 20, 2015, 09:55:19 AM »
KT
I'm not sure about the spacers, they'll probably call for finite element analysis on the loads put together by some expensive propeller head  - I do know that they are  pedantic when it comes to the wheel track,especially the front,from memory they give you 50mm over the original and that's it , no more questions.not negotiable.
Good luck with it.
« Reply #12 on: June 20, 2015, 07:39:56 PM »
We had it argued here about the adapters. If the adapters center is a snug fit on the mag it's actually stronger than original
Sorry KT, don't know of any off hand. Postage from NZ to OZ for complete heater would be a bit though
Offline KT
« Reply #13 on: June 20, 2015, 07:52:38 PM »
No worries Busy ... Just trying to get something for the reg as a demister is required. I am still a fair way off though so I'll make something up. Thanks anyway.
