  • Dot Guests: 156
Author Topic: Givin the van a tickle  (Read 65887 times)
Offline phill
Re: Givin the van a tickle
« Reply #30 on: July 19, 2015, 11:33:22 AM »
Hi George standard hole sizes in the kit are 60,49,43,34,28,22 mm,I think you can get square dies,1.2mm thick will be fine but I recon you might be pushing it with 4mm? not sure of the limits the electrician's use on thin cabinets
the ram on this sucks in most presses push out so i don't think you could combine the two?
hope this helps.
Phil
Offline phill
« Reply #31 on: October 16, 2015, 05:14:00 PM »
hi buga's now that winter is over and its wormed up iv been playing with the hole in the floor and other stuff here's some pics
i folded a new floor member which became part of the cover mount and some other angles for the rest of the cover mount also i cut into the fire wall a bit so had to fill that in
Phil
Offline Gunning
« Reply #32 on: October 16, 2015, 06:40:17 PM »
Bloody hell, nice work, nice and clean
I like the yellow colour as well
Offline phill
« Reply #33 on: October 16, 2015, 06:46:13 PM »
cheers Gunning i still cant decide on a colour yet
Phil
Offline phill
« Reply #34 on: October 17, 2015, 01:37:00 PM »
using some aluminium to make a template for the eng cover good old gaff tape, i modified the cruise control cable bracket and mounting point on the throttle control thing, rotated the hole thing 90 degrees so it will fit under the cover, modifyed the fire wall and pedal box for the vt-vz booster and got the boys at work to machine a sleeve with a flat tab on the end for the pedal connection
Phil
« Reply #35 on: October 18, 2015, 06:41:04 PM »
looking good man :)
cant go without cruise control, that's the cherry on top :)
I like the commodore shifter cover! and I also love the crow cams sticker on the back window :)
Offline Archie
  • probationary
« Reply #36 on: October 19, 2015, 01:51:15 PM »
Hey mate my name is Paul I've been hunting a beddy the past 8 months I was wondering if you know of any for sale please contact me call or text me on 0438 863 323 cheers
Offline phill
« Reply #37 on: October 19, 2015, 04:39:12 PM »
cheers Sammy yes cruise control was a must, i made this jig to form the radius's on the ends of the shifter cover so the black cover tongue thing on the shifter can bend down as you change gear, bend a bit push through a bit bend a bit and so on
sorry Paul can't help keep looking mate you'll find one
Phil
« Reply #38 on: October 20, 2015, 10:12:54 AM »
reminds me of how I work in my shed, make little things to do stuff :) I've done a lot of sheet bending along the top of the bench edge with g clamps and lengths of angle iron and such :)
when you don't have the tools or room and money to get them sometimes you just have to improvise :)
Offline phill
« Reply #39 on: December 02, 2015, 08:36:16 PM »
hi buga's been playing with the front brakes
I copied Reid's conversion using vn front hubs, cut the disc of and machined to fit inside a vt-vz front disc
also used the same outer bearing that Sammy found with the smaller OD size
thanks Reid,Sammy for the info, that's what's grate about this site all the differant ideas and info
next is the plate to hold caliper on
Phil
