  • Dot Guests: 314
Author Topic: Givin the van a tickle  (Read 65349 times)
Re: Givin the van a tickle
« Reply #20 on: May 27, 2015, 10:46:59 AM »
Shane is working on the gallery in his spare time, of which he doesn't have a lot of.
I've tried to offer my help but nothing has come of it.
Why not, I think a lot of people used these Galleries for ideas for their own projects, Shane help is here in what ever form is required just ask mate  :)
« Reply #21 on: May 27, 2015, 12:07:49 PM »
Any news on its progress?
Ive asked a few times.
« Last Edit: May 29, 2015, 08:00:41 AM by Marishka »
Offline phill
« Reply #22 on: July 11, 2015, 11:47:10 AM »
haven't done much on the van for a couple of months cause the shed is freezing of an arvo now that winter has set in but the van isn't going to finish it,s self so iv rugged up a few times and had a bit of a crack.
been playing with the dash using some parts from the vn dash as I'm using the vn wiring loom.
few pics
Phil
« Reply #23 on: July 13, 2015, 04:03:52 PM »
that works out nicely :)
i know what you mean about the weather I've been finding it hard to get outside after dark without freezing!
« Last Edit: July 13, 2015, 04:06:37 PM by Sammy »
Offline johnb44
« Reply #24 on: July 13, 2015, 06:46:08 PM »
looking good  8)
Offline phill
« Reply #25 on: July 16, 2015, 07:21:58 PM »
thanks sammy, john few more pics of the dash, I haven't played with bog for years
Phil
Offline Rogerfied
« Reply #26 on: July 16, 2015, 08:32:34 PM »
Excellent job it looks really good :)
« Reply #27 on: July 17, 2015, 10:34:59 PM »
Thats comming along a real treat ;) ;) :D
Offline phill
« Reply #28 on: July 19, 2015, 06:51:55 AM »
borrowed this hole punch from work I was thinking of using a holesaw to cut holes for the big grommets on the commodore wiring loom but this was much easier and neater cuts a perfect hole with no sharp edges
Phil
« Reply #29 on: July 19, 2015, 09:28:03 AM »
Hey Phill, i have been looking at getting one of these. H&F have them for a good price, but also looking at a 10ton bench press, question is can you use or get the dies for the hole punch to work in the bench press, 1 tool 2 functions ?? also if i went the hole punch can you get a large range of hole sizes as an accessary or do the dies come in the standard sizes for grommets and so on ?? and finally what is the steel thickness limit on the punches, i normally work with 1mm and 1.2 mm sheet steal, but with my hand controls for the buggy i was working with 3 and 4mm flat bar.
