  • Dot Guests: 315
Author Topic: Yoke/ universal joint  (Read 9195 times)
Offline Strangy21
« on: May 14, 2015, 02:20:48 PM »
Hi all-
New to BUGA. I'm buying a mates 80 CF Beddy. It's undergoing a blue slip inspection and we are stuck here. It has a 4 speed celica gearbox mated to a Holden tail shaft. So before mechanic will pass blue slip it needs a yoke/ universal joint as the one in at the moment is stuffed. Would appreciate any ideas please.
Offline johnxb351
weak drive line
« Reply #1 on: May 15, 2015, 01:47:54 AM »
Hi.   maybe if you could find a celica tail shaft and get it cut and welded and balanced to your holden tail shaft but finding one would  be your next problem.  i got to ask why is there a celica 4 speed in it ? . is it a holden 6cyl in it.   maybe the celica yoke is not strong enought for the exta  6 cyl power and the weight coming back thought the drive line as the CF is a lot heaver than the celica car and i would not think the celica gear box would be stronger than a holden  Aussi 4 speed gear box. . in the long run you might be better puting a holden Aussi 4 speed it. and get your mate to ajust his price lower to cover your cost of fitting a Aussi 4 speed gearbox in it.
Offline johnxb351
Re: Yoke/ universal joint
« Reply #2 on: May 16, 2015, 11:35:02 AM »
Hi strangy 21.   I best welcome you  here  since your new here  and i have given you info before welcoming you here .where were my maners :-\.  i hope other welcome you here and have some more input  other than me.  so come lads surely there must be more input  other than me  i have been knowing to be wrong at times
« Reply #3 on: May 18, 2015, 02:09:21 PM »
is it that the yoke is not good enough or is it just that the yoke itself is stuffed ?
from my experience with celica 5 speed conversion you need a yoke that fits the celica box with holden 6 uni joint on it, these normally come with conversion kits but you can probably get them separate from dellow or Castlemaine rod shop .... then it would just need a suitable uni which would be from the holden range off the shelf parts ....
also as far as I am aware the celica 4 speed it pretty much the same as the 5 speed, albeit with one less gear and different extension housing.
Offline Strangy21
« Reply #4 on: May 29, 2015, 01:30:01 PM »
Hi all
Thanks for the welcome. So problem is now solved. I have a new yoke/ uni joint welded and balanced to fit the holden tail shaft. Apparently now strong enough to run a V8. Ive still got the Celica 4 speed. I'm wondering if i should put a 5 speed in at some point. I dont know why all the original modifications/ why not have an aussie 4 speed instead of the celica. Anyway im hoping to pick her up Mon or Tues....
Offline johnxb351
« Reply #5 on: May 31, 2015, 02:16:55 AM »
Hi Strangy good to hear your problem solved.  a 5 speed  over drive gearbox would be good if your diff ratio is low and you do a lot of hwy driving to cut down on high rpm at 100km`. i think most 5 speed  overdrive gearboxs are about 17% overdrive.   if cutting high rpm down is your goal when driving on hwy you could put in a taller diff ratio in is  other way to go
Offline johnxb351
« Reply #6 on: May 31, 2015, 02:31:38 AM »
from what i have read the supra  5 speed is a strong overdrive gearbox
Offline johnxb351
« Reply #7 on: May 31, 2015, 05:22:51 AM »
google -   celica 5 speed into old holden          good info there
