  • Dot Guests: 136
Royal Bedford by wendyh
Author Topic: 186 compressed or 202?  (Read 26856 times)
Offline joshua
  • aghh finally on the road
« on: April 10, 2015, 04:49:03 PM »
Hey Guys,
I have been offered a 186 compressed engine in really good condition, I was thinking of changing over to a 202. What would you do?
What is better for:
Fuel
Noise
Power
Kind regards
Joshua
Re: 186 compressed or 202?
« Reply #1 on: April 10, 2015, 07:26:25 PM »
186 are better on fuel and not the much less in power.
Offline joshua
« Reply #2 on: April 11, 2015, 01:02:14 PM »
Awesome!!!! thats what i wanted to hear!
« Reply #3 on: April 11, 2015, 01:16:18 PM »
what do you mean by compressed
« Reply #4 on: April 11, 2015, 01:39:09 PM »
High compression 186?
« Reply #5 on: April 11, 2015, 06:33:52 PM »
o.k......put a 173 head on as well....red or blue...
Offline johnxb351
blue 202
« Reply #6 on: April 12, 2015, 12:14:32 AM »
go a blue 202 . more torque than the red motors and  the torque  is more spreed out thought the rpm range.  as standed they have HEI ignition , better breathing head. put some extrators on them and a 34 ADM WEBER carby  is a good set up..  and be good on fuel .if you go too high in compression  with todays fuel even with say 98 fuel  you will end up with pinging or knoking problems.
Offline joshua
« Reply #7 on: April 12, 2015, 11:33:07 AM »
Hi marishka, Thats what the dude selling it said.. im a little confused now ;) will a blue 202 bolt straight in with no modifications?
What would the best in regards to fuel and low revs...
« Reply #8 on: April 12, 2015, 04:18:39 PM »
Hi Joshua
A blue 202 will fit exactly as a red.
Only the carby sticks out more on passanger side.
U will need to put your red sump and oil pickup tube on the blue .
Im just about to do the same to my green/white poptop.
Cheers marty
« Reply #9 on: April 12, 2015, 07:00:31 PM »
I have a blue/black head on my 186. The manifold has been modified so a standard 186 carb fits AND without modifying the engine cover. It is so tight that I have had to remove the insulation/soundproofing around the carby.... but it fits under the standard engine cover.  ;D
Will let you know how it goes economy wise.... heading to WA from Adelaide, leaving on the 18th.. So you WA BUGA's - WATCH OUT!
 ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D
