  • Dot Guests: 325
Author Topic: JAG DIFF IN BEDDY  (Read 4838 times)
JAG DIFF IN BEDDY
« on: March 07, 2015, 01:52:39 PM »
was going to fit boarge warner diff..found jag irs for the same price...
how many beddy out there with jag diffs....
easy job?????
Offline Bean
Re: JAG DIFF IN BEDDY
« Reply #1 on: March 07, 2015, 02:37:07 PM »
I had one in my first Van ,all out of its cage and chromed,looked stunning with the inboard discs and coil springs exposed, 25 years ago we weren't too bright in the engineering department so the stabilizer bars cracked the body  -The net result - when changing gears you inadvertently changed lanes as well. Not the safest bus on the road but we were young and stupid at the time.
If you plan to go ahead with it you'll need to apply through Welshpool to do the mods, once approved they will then give you the go ahead and once its done it will need an engineers certificate to have it  registered, the certificate will probably include an on road break test which is not cheap, not many guys are prepared to do it .
You're  probably in for around $750.00 worth of paper work ahead of you if you choose to do it legally.
« Reply #2 on: March 07, 2015, 02:50:59 PM »
thanks........nothing is cheep these days.......
« Reply #3 on: March 08, 2015, 05:41:14 AM »
Rogue trooper did a thread on here (his thread) when he fitted his jag rear
http://www.buga.com.au/index.php?topic=222.msg38445#msg38445
