  • Dot Guests: 306
Author Topic: disc brake questions  (Read 8742 times)
Offline Marky
« on: February 04, 2009, 07:21:25 PM »
I have a PBS disc brake system on my CFS
Upper Beddy Ball joint
Lower Hq Ball joint
Running with Standard but resleeved
 Lockheed Beddy Master Cylinder
My Wreck has
Girlock Disc Brake set up
standard upper n lower beddy ball joints
Running with what looks like a holden master cylinder
Can i run the Girlock set up with my Lockheed Master cylinder or do i have to swap to the holden one ??
Any help or knowledge will be appreciated
Marky :o
Creative Media Producer
hammers_spanners
Re: disc brake questions
« Reply #1 on: February 04, 2009, 08:49:30 PM »
Why the need to change? If the brakes are working ok. Check the bore of the master cylinder to make sure they are compatible. Bigger bore = more fluid  = more force applied! Just a note that if too much force then the rears can lock up or blow wheel cylinders.
Craig
Offline Marky
« Reply #2 on: February 05, 2009, 09:19:12 AM »
Well the 2 Pins which hold the caliper on are worn and the whole assembly rattles
Priced kits to rebuild them $100 each..get calipers sandblasted n good as new
But Kits are out of stock ...aaaarrrggghh
..so my local brake place tells me ..something to do with Hq racing or could be bullshit ?
But I have this wreck with the Girlock set up sitting in my yard and would like to use it if it cost less..
...girlock set up is biggerbrake n caliper too
hammers_spanners
« Reply #3 on: February 05, 2009, 09:22:33 AM »
If you are swapping calipers and master cylinder that should be ok. Just check the bore size re rear brakes.
Offline Marky
« Reply #4 on: February 05, 2009, 10:50:09 AM »
Hey craig
 I dont want to swap master cylinders unless i have to..
had my beddy one resleeved 5000k s ago
was wondering if i can use my beddy master cylinder with Girlock Hq set up
Many Thanks
Marky
« Reply #5 on: February 05, 2009, 12:07:51 PM »
Hey craig
Many Thanks
Marky
Marky, thats what my van is running, without problems.
Offline Worzel
« Reply #6 on: February 05, 2009, 01:41:51 PM »
i believe you need longer bolts for the Girlock calipers, but you should have them on the doner
The castlemaine rod shop kit comes with two different length bolts for different calipers
www.memoria.com.au/DB022.doc
Kit Contains:
4  off  1-3/4" x 7/16" UNF bolts (when using PBR caliper– cast iron type.)
4  off  2" x 7/16" UNF bolts (when using Girlock caliper– cast iron type.)
Apart from that they are physically interchangeable.
If caliper piston is larger then more braking force, if smaller then less
So long as master cylinder can deliver enough fluid you should be OK (?)
« Last Edit: February 05, 2009, 01:47:17 PM by Worzel »
Offline Marky
« Reply #7 on: February 06, 2009, 11:54:37 AM »
Thanks Peoples ;)
« Reply #8 on: February 06, 2009, 01:51:35 PM »
anyone got a second hand kit they wanna sell?
or just the 2 caliper mounting brackets?
time for brakes that stop properly.
send me a priv message.
hammers_spanners
« Reply #9 on: February 06, 2009, 03:42:56 PM »
Hey Marty Ben's Fiberglass, Chroming, Juke Box Hire and NOW Taxi Trucks will be bringing 2 caliper mounts for you.  ;D ;D
Craig
