  • Dot Guests: 322
Author Topic: where do you get things like clutch cables accelarator cable engine mounts.  (Read 12821 times)
Offline joshua
  • aghh finally on the road
Hi guys im after a few small things.. Ive tried don kyats, and jo from dandenong with no luck so far... What im after are the following
Break wheel cylinder x 2 rear
engine mount
clutch cable
accelarator cable
break lines
spigot bearing bush (crank end for a supra)
mount for a supra...
Most of that stuff you should be able to get from places like repco, super cheap, auto stop, BNT
They should be able to do it all, even clutch cable
Offline willo
engine mount
clutch cable
accelarator cable
break lines
Hi mate,
there is a guy in Lismore, NSW who makes new handbrake or clutch cables from a sample. Look up Wright's Clutch Service.  He has all the various ends and knobs and cables and ferrels etc and just needs the sample to get it all spot on for you.
I've used him a couple of times and been happy with his service and price.
and importantly, he isn't related to me nor do I have any interest in the place.
Neil
I modified a generic accelerator cable to suit my van
Offline Postie Bob
I replaced my wheel cylinders with ones from a Mini Minor. They are just about identical and work fine.
Helluva lot cheaper than originals too  :)
From memory there`s a left & right cylinder needed.
Cheers, Bob.
Offline Bedford Fever
     Hey Joshua , l got my brake wheel cylinders recoed by a company in Thomastown
                          Called Vac Air Services ph (9464-2122 ) they also made new rubber brake lines
                          Hoses were  $30 each , the rear cylinders were $ 45
                           Flexible Drive Agencies in Kensington 9381-9222 , made me an accelerator cable
                            For $ 55 , they also make hand brake cables.
                           Hope this can help you since your in Melbourne
                           Cheers Frank
Offline joshua
thanks guys I ended up going Dellow conversions.. was a little prices.. $110 per cable custom made. he also has Engine mounts and spigott bushes for conversions of gear boxes...  cylinders i got all four form $35 ea which i thought was pretty good.
