  • Dot Guests: 293
Author Topic: Bedford/Holden temp gauge  (Read 9305 times)
« on: February 01, 2009, 07:15:31 PM »
I took my standard van for a blat today, was fun until it blew it's top. The water pump and half the hoses were blocked solid, hopefully no head damage.
Question: Do the Ozzie 6 cly bedfords use the original bedford temp gauge with holden sender (recalibrated), bedford sender with bedford gauge or holden gauge and sender ?
Re: Bedford/Holden temp gauge
« Reply #1 on: February 01, 2009, 08:15:43 PM »
i dont know!!!!! but im interested to find out..
ive always just grabbed senders off other motors n stuff so i asume its standard holden sender.. and im not sure if the guage is holden or bedford.. only because i know the temp guages that came with the 71 - 74's looked different?? mind you so did the fuel guage.. so go figure!!
Offline Worzel
« Reply #2 on: February 02, 2009, 06:51:05 AM »
an aftermarket gauge is pretty cheap and well worth it
« Reply #3 on: February 02, 2009, 08:19:05 AM »
last time i bought an aftermarket one it was flippen 50 bucks!! didnt think that was very cheap eh!! lucky it wasnt for my van lol
« Reply #4 on: February 02, 2009, 03:57:19 PM »
Standard Holden sender, Bedford guage, don't neet to recalibrate. ;)
« Reply #5 on: February 02, 2009, 05:59:11 PM »
thats weird, currently I have holden sender and bedford gauge (81 beddie model) and the red is when the thermostat opens
« Reply #6 on: February 02, 2009, 06:14:55 PM »
Sender 1980 holden, Gauge 1980 Bedford, works fine check themo, Replaced it with a 1981 mk 2 once did not work, the gauge is Bedford for sure as I have a second guage here and it's the same. Van was shipped in new from Aussie cab and chassie with 202. You could also replace you gauge with a smith one they are calibrated very close to the Beddie as they where made around the eighties and we used to fit many of these to our custom dash's when  I worked in this field and all worked fine. :D If all fails just get year and model of Holderen Motor and fit the guage from same car, problemed solved I guess.
« Last Edit: February 02, 2009, 06:21:14 PM by Bas NZ »
« Reply #7 on: March 21, 2009, 06:07:40 AM »
For anyone else that may have the problem of the temp gauge going into the red ... the fault/reason was a stuffed voltage stabilizer
« Reply #8 on: March 21, 2009, 05:58:10 PM »
yeh please busy explain!!! i spent 2 hours trying to fix my temp guage.. knew it was electronic.. and i hooked an earth to the wrong place.. and now?? its all over..  ive fryed something.. hope its the stupid voltage stabilizer!!
where do i find this rodent?
ive since bought a mechanical temp guage to get me by while i fix the other.. actually i think ill use both. cant hurt.
« Reply #9 on: March 22, 2009, 06:49:58 AM »
It's behind the dash, is a rounded rectangle in shape and has 3 wires coming of it; earth, gauges (temp and fuel) and live from fuse box.
I'm going to have to pull my dash out soon to replace the speedo inner so will try and get a photo of it.
