  • Dot Guests: 342
Author Topic: Radiator model?  (Read 4826 times)
Radiator model?
« on: October 01, 2014, 01:55:44 PM »
G/ day
Does anyone know what kind of radiators a standard 6 cylinder
Beddy uses???
Im thinking they are holden HG Ht Hk
Cheers marty
Offline VanWolf
Re: Radiator model?
« Reply #1 on: October 01, 2014, 02:44:43 PM »
Marishka,
I have a radiator that I wont be using, as I am converting from a 6 cylinder to a V8.
Where about's you located?
Mike
« Last Edit: October 01, 2014, 04:05:25 PM by VanWolf »
Re: Radiator model?
« Reply #2 on: October 01, 2014, 03:26:24 PM »
yeah from my experience with mine, it was similar to a torana 6 cylinder item.
Re: Radiator model?
« Reply #3 on: October 01, 2014, 07:39:55 PM »
I always thought the Torana units were shorter by about an inch- to clear the lower bonnet
I would go HQ/HX.
Russell
Re: Radiator model?
« Reply #4 on: October 01, 2014, 07:42:55 PM »
Marishka,
Mike
G/ day mike im in between liverpool n penrith
Cheers marty
« Last Edit: October 02, 2014, 12:56:43 AM by Marishka »
Re: Radiator model?
« Reply #5 on: October 02, 2014, 12:59:39 AM »
G/day Russell, n sammy.
I originally thought HQ-HZ,
But the side mounting plates are too wide.
HK-HG seem more like it.
Im not sure about torana.
Cheers marty
Re: Radiator model?
« Reply #6 on: October 02, 2014, 05:21:45 AM »
I think they were HT, as the HQ have the wide sides
Re: Radiator model?
« Reply #7 on: October 02, 2014, 07:45:08 AM »
yeah I also have no idea if the Torana one is smaller, I just know that's what I used in my EK  and also it looked very similar to the one I pulled from the Bedford!
Offline AndrewOC
Re: Radiator model?
« Reply #8 on: October 03, 2014, 09:14:02 AM »
I have trimmed down side brackets of HQ and re-drilled holes before, and it worked.
cheers,
A.
Offline Bedford Fever
Re: Radiator model?
« Reply #9 on: October 03, 2014, 07:48:15 PM »
       I bought the HQ to HZ radiator with the long side bands from an epay store in Melbourne called Auto coooling and electricals .
      I would have bought the HD HR to HG with the short side bands , but the HQ to HZ ones were on special at the time .
      Both cores measured the same 370mm x 530mm
      To save myself any cutting , l took my old radiator to the local radiator guy and got him to change the bands over , took him 5 minutes to do .
      If your any good with heat and solder you could do it yourself   .
      Cheers Frank
