  • Dot Guests: 250
Author Topic: Holden Front Disc Brake Kits for CF  (Read 17017 times)
Offline Davidjt87
« on: September 14, 2014, 03:52:16 PM »
Hey im wondering how many people would be interested in a ready to bolt up brake kit on here, I can make these kits for around $600nz, Possibly cheaper dependant on a few fiddly things which im trying to get my head around atm.
Cheers David
Re: Holden Front Disc Brake Kits for CF
« Reply #1 on: September 14, 2014, 04:42:22 PM »
You in Oz or NZ?
McQuoid Engineering does disc brakes (using hq or commodore calipers), power steering and diff conversions etc for CF in Auckland NZ, check him for prices
« Reply #2 on: September 21, 2014, 08:55:49 AM »
Using what parts David?
Offline Davidjt87
« Reply #3 on: September 21, 2014, 09:59:15 AM »
hi, im from Auckland/newzealand, ive used vk hub, falcon inner bearings, aftermarket outer bearings(hub remachined) cf seal(hub machined to suit) Trojan 50.2mm grease cap, holden vu disks, holden vu caliper. Braided brake lines
Offline aussieneil
« Reply #4 on: November 13, 2014, 05:22:53 PM »
If this kit will retain the Bedford hub stud spacing (and therefore original wheels) I'm definitely interested.
Offline moose
    • Awesome sounding exhausts
« Reply #5 on: November 13, 2014, 06:06:52 PM »
Yep, definitely interested. I'm changing to HQ stud pattern and discs shortly. Might use the Falcon discs on the rear... but probably just stick with drums...
Offline LS120
« Reply #6 on: January 11, 2015, 02:52:58 PM »
is that a front set or each side David?
and are parts supplied or not?
Offline LS120
« Reply #7 on: January 11, 2015, 02:57:24 PM »
also could it be done with Bedford stud pattern? with blank (un-drilled) Disk's?
« Reply #8 on: January 11, 2015, 07:05:18 PM »
The ford/holden discs aren't wide enough to take the CF stud pattern
Offline LS120
« Reply #9 on: January 12, 2015, 05:06:47 PM »
any disc setups that are cf stud pattern?
