  • Dot Guests: 77
Author Topic: Cheaper option  (Read 4644 times)
Cheaper option
« on: January 29, 2009, 07:18:53 AM »
what have you found that is a cheaper option. and pro's and con's. ill start. (i expect some good ones from you ed!)
fibreglass bog.. $10 for 3 litres much cheaper than normal car bog.. $40 - 50 for 3 litres.
pro
fibreglass bog is waterproof!!! a lot harder. so cheap for the serious bogger!
con
pretty hard to sand (use an orbital and its fine.)
experimenting using fibreglass resin as a sort of high fill also.
doesnt seem to work as brilliant as fibreglass bog but will do some more experimenting. maybe with a little more powder in it it may be less sticky and work much better..
« Last Edit: January 29, 2009, 07:21:08 AM by ben »
Re: Cheaper option
« Reply #1 on: January 29, 2009, 11:15:27 AM »
i think i may have nailed the high fill thing.. i was not using enough catylist.. therefore it was sticky cause not going off properly!
ive just  been brushing it on.. but i suppose if you thined it down you could even spray it on.. and put food dye in it so its a color and you can see where youve been lol.
i could even make up kits for anyone interested in going the cheap way lol hahahaha!
even if it was a third of the price of bog it would still be worth it ay!
« Last Edit: January 29, 2009, 11:17:37 AM by ben »
Offline Mark B
  • '79 CF SWB
    • Some of My Music
Re: Cheaper option
« Reply #2 on: January 29, 2009, 08:18:15 PM »
i like your thinking, dude :D
you could even make mini kits, for doing small patch up jobs etc.and for putting around flared guards and spoilers..
http://abakersdozen.com.au
Re: Cheaper option
« Reply #3 on: January 31, 2009, 06:03:15 PM »
sounds good!
« Last Edit: January 31, 2009, 06:15:59 PM by ben »
