  • Dot Guests: 253
Author Topic: Cf truck motorhome Dual wheels to single on back  (Read 4426 times)
« on: September 01, 2014, 09:00:18 PM »
Hi all,
a bloke asked me today and im not really sure.
Does anyone know if a motor home with standard low speed diff and dual wheels on the back
can be converted to highway diff and wide single wheels without worrying about getting an engineers cert?
And if the standard big drum 6 stud front can be converted to Holden HQ disks without engineers cert?
Thanx for any info regarding questions.
Cheers marty
« Last Edit: September 01, 2014, 09:02:43 PM by Marishka »
Re: Cf truck motorhome Dual wheels to single on back
« Reply #1 on: September 01, 2014, 09:26:05 PM »
Marty, it will come down to the rear tyres load carrying capacity.
Most car tyres will only be about 7 to 800 kg max, while lt tyres are about that and more each! and there is 4 of them. :) and a motor home will be "heavy"
Personally, I wouldn't do either conversion.
As a question, has anybody investigated using fiat/transit/Mercedes  "parts" to do a disk front- I know a lot are FWD, but is it a viable alternative?
Offline LS120
« Reply #2 on: September 03, 2014, 05:01:44 PM »
the dual and single wheel rear ends are different and for different loads. (dual i think is cf-350 3-tone total) the drum size is different  also single being smaller.
« Reply #3 on: September 03, 2014, 07:25:37 PM »
Cool, thanx guys,
So i take it a LWB cab chassis motor home 3.5 ton wouldnt take a
chev 12 bolt single wheel diff
Not even with a fat single.  Say 15x 10 HQ stud pattern?
Is a disk brake front a no/no as well?
« Last Edit: September 03, 2014, 07:27:14 PM by Marishka »
« Reply #4 on: September 03, 2014, 08:32:45 PM »
Marty, go and download a catalogue of tyre sizes and that will give the load ratings. I have a Chinese brand on the truck when I bought it.... they have a good catalogue, with max load and sizes etc.
http://www.zc-rubber.com/en/productsdesc.php?cat_id=1
Please note I DO NOT RECOMMEND THESE TYRES, just the catalogue. But in saying that I have had no issues.
Russell
Offline Fat bed
« Reply #5 on: September 04, 2014, 02:51:38 AM »
I replaced my diff with a ford AU diff that bolted in perfect and gave me rear disk brackes I also replaced the from end with a HQ and had the disks drilled out to suit ford wheel pattern... I run a 202 with three speed box and she runs and stops like a dream.. great ratio's and the brake lines lined up easy. ... hope this gives you something to think about...
Luigi is part of our family....you mess with it you mess with us all.
« Reply #6 on: September 04, 2014, 09:14:12 AM »
Sounds good Fat bed,
What sort of beddy do you have?
CF350 ?
Whats its weight?
Was it dual wheels on back before?
Cheers marty
Offline Wiggo
  • probationary
« Reply #7 on: September 07, 2014, 10:04:38 AM »
For what it's worth, I replaced my dual wheel diff with a single wheel from an XH falcon ute. Fitted 15 x8 King wheels (Sunraysia lookalikes) with a + 13mm off set & 255/70 light truck tyres. Load capacity on the tyres is 1120kgs. Diff ratio is 3.25 - 100kph @ 2200rpm. Handles full loads very well.
Cheers Russ.
Bedford - always wanted one, now I've got one!
