  • Dot Guests: 192
Author Topic: window seals  (Read 6265 times)
Offline alice
window seals
« on: August 29, 2014, 04:28:53 PM »
Hey....I'm replacing my back windows and the seals are totally stuff an that goes for my doors windows seals.is rare spares the place to go?
Cheers alice.
Offline vuuup
Re: window seals
« Reply #1 on: August 30, 2014, 06:38:48 AM »
are you talking about the window seals that have a key rubber insert that hold the window in?? if so certain clark rubbers have them in stock, i needed to go to three different ones before i got them. watch some youtube videos on how install them as can be a bit tricky. made a insert tool out of a wiper blade steel and a file handle which worked perfect for the key rubber.
Offline alice
Re: window seals
« Reply #2 on: August 30, 2014, 08:11:13 AM »
Cheers vuup, yep those ones an also front door window seals, which I figure will much to get?? Will check out clarks...
Offline vuuup
Re: window seals
« Reply #3 on: August 30, 2014, 11:52:23 AM »
you can get front window doors rubbers from this guy http://www.scottsoldautorubber.com.au/BEDFORD%201977%20CFL%20VAN.htm , they are not cheap (not to bad if you just get the bit you need) and not exactly the same as the old ones but worked well for me. rare spares videos on installation into old holdens are helpful. can try matching some thing up at clark rubber but i did not have much luck, they will give you small off cuts to test for free.
Offline vuuup
Re: window seals
« Reply #4 on: August 30, 2014, 11:58:22 AM »
i think this is the clark rubber i ended up getting the rear window rubbers from
Clark Rubber Bundoora
Unit 2A/445-447 Grimshaw Street
Bundoora VIC 3083
(03) 9467 6677
Offline vuuup
Re: window seals
« Reply #5 on: August 30, 2014, 12:04:48 PM »
found that cutting the rubber a bit longer and testing the fit before i glued the ends together, as it shrinks a bit and also when it ages. especially the key rubber, i added a inch or so and squeezed it in and now you can not even tell where the seam is.
Offline alice
Re: window seals
« Reply #6 on: September 04, 2014, 03:06:22 PM »
Awesome.thanks so much.will do some running around town tomorrow.
