  • Dot Guests: 341
Author Topic: slipped into disc's  (Read 7119 times)
Offline photol
Re: slipped into disc's
« Reply #10 on: January 29, 2009, 07:25:35 AM »
.....sorry Guy's, I'll fix it up, just gotta find the link again....they are definitely duallies though...... :o
....it's not what you see....it's what you think....you see.
hammers_spanners
« Reply #11 on: January 29, 2009, 02:04:47 PM »
Have any of our Kiwi members info regarding this company?
http://technicast.co.nz/index.php?option=com_frontpage&Itemid=1
Offline Worzel
« Reply #12 on: January 29, 2009, 02:28:04 PM »
edited my post( deleted that one before anyone saw how dumb it was)
« Last Edit: January 29, 2009, 02:29:40 PM by Worzel »
« Reply #13 on: January 29, 2009, 06:47:34 PM »
Sorry don't know of them, but no an engineer that can make anything you could name. Built his own street rod, includes wire mag wheels, blower etc, very few of these guys left.
Offline photol
« Reply #14 on: January 29, 2009, 10:36:09 PM »
...this one's for you ben
Offline photol
« Reply #15 on: January 29, 2009, 11:07:14 PM »
....there is no God, if there was, he would help me keep my big mouth shut 'til I knew what I was talking about
.....ok then, like Wozral I'm begining to understand why I havent seen many ....any Lwb's running 16inch duals....
So just imagine five stud disc front  and a modified 9inch with Ford F series eight stud pattern dually rear.....(remember there is no God)
let's just say then that we don't mind carting around two spares, 'cause the front 16's are different from the 17.5's duals on the back anyway.......
And here's a very prompt reply from Hopper's stoppers......
Oliver
We have a 300mm twin piston kit available for the CF Vans so we know what
these front ends and the matching stub axle/hubs look like but not possible
to do any stud pattern bigger than (5 inch 127mm) pcd with our disc
conversion.
(F series is 170mm), I will attach some instructions for your interest.
That's just the front and these kits start from $1350.
Peter Koning
HOPPERS STOPPERS
9 Nevada Crt. Hoppers Crossing, VIC 3029
PH. (03) 97486950   FAX. (03) 9748 5965
300MM Brake kit suit Bedford CF Van
To replace factory drum brakes
•   A minimum of 15” diameter wheels are required, these should be of a suitable design to clear the disc brake assembly.
CONTENTS OF KIT
1 pair BA Ford rotors 504 in pattern as requested
1 pair AUII twin piston calipers & cradle brackets with pads
1 pair K1045 billet steel adapter hubs pattern as required
1 pair  Outer bearings L68149/11 Inner bearings K07100s/K07210x
1 pair Seals P1531  2.500” x 1.812” x  0.25”
1 pair Grease cap Mits type
2 x adaptor brackets DRG 96673 C shaped
2 x adaptor brackets DRG96672 trapazoidal shaped
4 off spacers 2mm thick by 13 bore by 25 o/d
4 x 1/2” UNF x 2 inch long Cap screws, nuts & spring washers
4 x 1/2” UNF x 3 ½  inch Cap screws, nuts & spring washers
4 x M12 x 1.75 x 40mm long bolts, nuts& spring washers
4 x M12 by 1.75 by 30 hex bolts and spring washers
1 pair brake hoses
2 x banjo bolts
4 x copper washers
« Last Edit: January 29, 2009, 11:16:22 PM by photol »
