  • Dot Guests: 188
Author Topic: slipped into disc's  (Read 7114 times)
Offline photol
slipped into disc's
« on: January 24, 2009, 11:05:06 PM »
Morning All
....the real issue is.... sometimes, at a glance, my CFL looks like a 60's model,  E300 Mazada concept light commercial, who's designers were tripping..... why?   'cause you can drive a Gogo Mobile into the empty wheel arch. Is this because back in the early 70's, 14in rims are ok with 7in high tyres on them ?
So change it.....       without losing the classic LWB "Dually" look, retain or increase ground clearancet and if we have to spend money, then make it better, much[/i ]better....
   why not just adapt large disc rotors front and rear ala Ford F350 series,or Dodge, maybe even Transit or toyota have  the new rotors drilled with desired bolt stud pattern, work the guards to suit custom 16" 17.5" or (go wild) 20" Dually wheels....voila, improved aesthetics better braking, ride and handling.
Quanto-costa.....estimating two to three grand or more, per corner, depending on how you went about it. Not tooo bad given every thing is new and possibly  certified. see you in three years when I've saved the dough..........
......or is there another way,           early F250 Duall split rims 15 or 16 inch (?)      perhaps a whacky Dyna
.....so far have come up with this.........
http://www.alko.com.au/vehicle/disc_brakes/m_brakes.htmlhttp://www.dragway.com.au/m_24.asp
http://www.hoppers.com.au/
http://www.customwheelsdirect.com/html/wheels_brand/wheel_detail.php?id=66820
« Last Edit: January 24, 2009, 11:25:26 PM by photol »
....it's not what you see....it's what you think....you see.
Offline Worzel
Re: slipped into disc's
« Reply #1 on: January 25, 2009, 10:29:09 AM »
yeah, every time one of those dual wheel F350 drives past me i think "hmmmmmmmm, that would be the business"
Has anyone ever measured an F350 diff, and sussed out the bearings required for the front (Yup, i'd rather follow than lead on this one :D"
Offline photol
« Reply #2 on: January 26, 2009, 09:47:38 AM »
...er, yes,....I lament the loss of being able to modify one's postings the next day.....my rather naive ramblings above have a bit of a "cringe" factor.....never the less, I was hoping that in thirty plus years of CFL Bedford existence, some one must have put 16's on one by now....or it just simply ain't possible......
....so in this regard, Worzel, I'm probably not the one to follow, as I may just lead you astray....but I will continue the research and post my findings....
Offline Worzel
« Reply #3 on: January 26, 2009, 11:54:38 AM »
yeah, i have a few posts that i wish i'd thought about a bit more.
fitting 16" rims isn't a hassle with the single wheel diff as i (misunderstand?) it.
Holden HQ pattern 16" rims if you have holden pattern single wheel diff,
But those F-series with the 18" chrome dual wheels, hmmmmm, me like.
Probably is a bearing combination to suit the  front, but the disc caliper adapter plate, that's gonna be a custom jobbie.
I know i'm never gonna go near looking at it seriously, still, no harm in dreaming ::)
« Reply #4 on: January 26, 2009, 12:32:37 PM »
I would have thought that the duallies brakes would be up to the task, and then just find some of those alloy rims - would look sweet
Offline photol
« Reply #5 on: January 27, 2009, 09:49:58 PM »
..these day(and nights)I'm having trouble telling the difference between dream state and waking state. Although a  request for money often snaps me back to this reality.
so let's call this a research project,
I asked Dragway engineering if they can make dual wheel rims, they cannot.
there is a guy selling 9inch diffs that range in price from $750 t $950 depending on type, this may give access to ford f series rear wheels, but there are probably other issues......
ask the brake engineers next.....also carry tape measure and buy a set of electronic vernier calipers....
find some early 84 transit wheels and discs.....as worzel is thinking, and others I'm sure....
 a last resort may be finding some high profile 14's.....but there is plenty of time yet
Offline photol
« Reply #6 on: January 27, 2009, 10:39:11 PM »
...hey is this an early transit with discs ? it certainly has DUALLIES
« Reply #7 on: January 28, 2009, 08:35:04 AM »
cant tell man its way too small!!
hammers_spanners
« Reply #8 on: January 28, 2009, 12:56:42 PM »
Come on Olli at least give us a good look at the gir... um ford. I just read this site for the vans, really!
hammers_spanners
« Reply #9 on: January 28, 2009, 02:26:06 PM »
Ok Olli I have found a wheel supplier who may be able to help. Can do 5 Stub rims in Bedford pattern. May be able to do 6 Stud 17" Super Single in a Bedford pattern
I need Sydney members near Castle Hill with 5 stud and 6 stud Bedford pattern wheels to drop in so they can measure up.
PM me with your contact numbers please.
Craig
