  • Dot Guests: 185
Author Topic: How To - keep back doors from opening  (Read 11592 times)
« on: August 05, 2014, 10:49:26 AM »
The back doors can open by themselves when cornering. The main reason for this is structural rust, most likely at the bottom of the back door pillars. Also rust around the windscreen can aid in this as well.
#1 fix would be to fix the rust, even if just back pillars and weld in a gusset at the bottom (going from pillar to section under tail light)
#2 (band aid fix) is to get the longer door stays/latches/catches (whatever you want to call them) at the top and bottom of each back door. They come in two lengths, normal and longer. Most vans come with the normal ones, by swapping to the longer ones it can stop the doors from opening (van can't twist enough to pop them out).
I have never found a model, year or version of van that had these longer ones so you'll just have to keep your eyes open.
Even just replacing one on drivers side (main door) can be enough as that door has to open before the other one can.
I'll try put up a photo soon
Offline Postie Bob
Re: How To - keep back doors from opening
« Reply #1 on: August 05, 2014, 11:06:26 AM »
Another way to stop the doors opening  ;D ......
 http://www.buga.com.au/index.php?option=com_gallery2&Itemid=8&g2_itemId=49114
Think I better move the number plate.
« Reply #2 on: August 05, 2014, 02:01:16 PM »
I take the bottom stay plates off and cut 2 small square holes out so the stays
 slide into the recesses deeper.
Then just refit the plates. (Only cut the square holes 1mm bigger than the square block that slips into it)
Works a treat.never had the doors fly open since.
Offline Truck
« Reply #3 on: August 05, 2014, 10:38:28 PM »
My bottom guide has a piece of 4-5mm rod spot welded across it to rear side of holes that catches the back of the latch. This gives an extra few mm for latch before it comes out releasing door and is smooth so you don't get snagged.Will get pic.
« Reply #4 on: August 06, 2014, 05:48:27 AM »
The rod was a common fix, but the door can still come open with it on and as the rod is usually only mild steel it wears out
Offline atk1
« Reply #5 on: August 06, 2014, 01:45:10 PM »
My back doors (in my main van) have luckily never opened by themselves however I would rather have a whole new catch setup. Something like the newer transits so that any old Joe can open & close them without having to know the special technique. I dont let anyone close them because of the handle scrape that will happen on the paint haha
Offline Truck
« Reply #6 on: August 06, 2014, 11:54:54 PM »
Yeh Busy the mild steel won't last long on a daily but mine is a Sunday driver and the previous owner used stainless rod which should last a bit longer. My old lwb was a shocker for this and I tried a few options but the body flex was impossible to stop.
Offline kimbosound
« Reply #8 on: August 13, 2014, 12:11:13 PM »
Fiberglass one piece door that goes up so u can get our of rain when loading if need too.
That was one condition Ray said to me, that had to go, if we were to get another beddy...
the back barn doors have to go !
« Reply #9 on: August 13, 2014, 12:18:35 PM »
We took a beddy to Weipa far north QLD.
800 km of corrogations and dips..creek crossings.
Most of which where dry ...nearly every crossing the back doors came open as the creeks were no flat and the van twisted and flexed.
sometimes we wouldnt know the doors were open untill the bull dust became very think inside.
By the time we got to Weipa we were browny red...everything was covered in dust. :(  >:(
so we emptied outhe van and hosed out the inside.
When we evetually left Weipa we covered up every conceiable hole and duct tapped up the back doors.
we were prepared this time!
only a small fraction of the dust we experienced on th eway up.
first two are in Weipa
third pic is when we left weipa and bought a catamaran in Mackay!
