  • Dot Guests: 369
Author Topic: What have you been up to this week  (Read 4312188 times)
Offline grandad
« Reply #820 on: February 14, 2010, 12:22:21 PM »
7th grandchild little girl ashlee rose 7lb 19in
« Reply #821 on: February 15, 2010, 03:42:47 PM »
way to go... heartfelt congrats gramps.... let us know when ya not busy sometime an ill venture forth from the hub of the known universe an help u wet the babys ead if yor up for it bloke ;D cheers skippy
Offline grandad
« Reply #822 on: February 15, 2010, 03:57:27 PM »
no worries skippy i am up in pirie now and a gain seeing the kids will let you know when i am up again and have a beer or four
« Reply #823 on: February 15, 2010, 04:17:41 PM »
ok what does this look like its got inside it...
any ideas
« Reply #824 on: February 15, 2010, 04:26:45 PM »
cant really tell from the top. give us a look at the backing plate..  althou it having a flange on it means it could be   borg, bedford, holden commadore.. centre
9inchs, 12 bolt salsbury, 10 bolt chev diffs, dont have flange
« Reply #825 on: February 15, 2010, 04:51:28 PM »
ten four gramps ;D.  LS. . at a guess it has a crown & pinion & some bearings in it..less woz a trick question an u took em out  ;D more info would be helpfullerer..eg any casting no,s or codes or anything on the housing??  would help identify it betterer ;)
Offline waikatostocky
« Reply #826 on: February 15, 2010, 05:28:35 PM »
That looks very similer to the 9" brake drum bedford houseing. i have rebuilt one with cresta gears and just put in my SWB.
Paddy
be safe out there
« Reply #827 on: February 15, 2010, 06:21:21 PM »
looks about the right length to be a cresta crown wheel and pinion
« Reply #828 on: February 15, 2010, 07:31:32 PM »
its out of a cf light truck with a 202 & 4 speed (holden) i think.. single leaf spring. looks like my other beddy case's i got.
hope it is a cresta as i need a better on than a standard i got now.
i,ve put the 202 in & left the beddy 4speed in. goes over the rumitucker hill in 3rd both side about 50+ km
open road a bout 80km so need more (90-95km) would be fine.
« Reply #829 on: February 16, 2010, 01:14:52 PM »
My Cresta Diff has a ratio of about 3.45 to 1.
The way to measure them is;
 lock one wheel (or leave on ground),
mark a point on the pinion,
turn the other axle 2 (two) complete revolutions, counting the turns of the pinion,
The number of turns of the pinion is your ratio.
this does not work (I think) on limited slip diffs.
Edited due to misprint.
« Last Edit: February 16, 2010, 05:01:54 PM by Jeff »
