  • Dot Guests: 388
Author Topic: What have you been up to this week  (Read 4312124 times)
« Reply #710 on: December 16, 2009, 01:26:11 PM »
about to attempt a high speed diff conversion ,borg warner center bedford stud pattern.
im proud of you craig!!!
hey i forgot to tell you i have a bedford hwy diff in pieces ((bent the pinion)Ran it out of oil, silly me) with a borg centre on the 10inch drums, 21 spline axels  i should be able to get some photos at some stage, may be of use?
« Reply #711 on: December 16, 2009, 02:34:33 PM »
hey ben,,just found out the driver side shorter axle  of my 21 spline is worn too much ...sigh.. so  needin to replace, in melb at mo till weekend but limited with internet access at a mates in morn pen area at mo will be in touch cheers tim
Offline kimbosound
« Reply #712 on: December 16, 2009, 05:02:42 PM »
it is off to the beddy graveyard,,,,,,i am sure her donor organs will be put to good use.
More pic here -
http://www.buga.com.au/index.php?option=com_gallery2&Itemid=8&g2_itemId=16125
« Reply #713 on: December 17, 2009, 07:36:10 AM »
kimbo how long did it take you to strip it out? and did you use air tools?
i hope you grabbed the wiring loom if it was in good nick:)
« Reply #714 on: December 17, 2009, 11:23:33 AM »
hey Kimbo what are the lower rear quarters like Craig is on the hunt for some  Cheers Neil
« Reply #715 on: December 17, 2009, 12:23:44 PM »
ah the bumble bee is no more  :'(
Offline kimbosound
« Reply #716 on: December 17, 2009, 12:33:00 PM »
Hi all,
Ben - took 2 full days with a socket set and a few spaners  & a trolly jack [no power or air up the back of the yard all hard labour by my self], and got most of the wiring loom.
Merlin - The rear 1/4s are knackerd, bent and rusted beyond repair sadly. The only thing left on it is the rear springs and some rusty brake lines.
Offline kimbosound
« Reply #717 on: December 22, 2009, 10:15:54 PM »
rubbed back the filler prime on the truck and noticed quite a few dings and minor dents so i decided to put in some filler. Went to super cheap auto and got a tin "O" bog mixed it up and slapped it on.........5 hrs later it was still wet? truck was even out in the sun. So i dug it out [really pissed off at this point] mixed up a hotter batch and tested it for hardness prior to making another batch.....still wouldn't go hard.....so then i really upped the anti with the catalyst and 6 hours later still wet.....was hoping to get into paint tomorrow...now 2 days behind....will have to wait til after xmas now!!!!! grrrrr ......musta got a dud batch of hardener
Offline Rothu
« Reply #718 on: December 23, 2009, 06:54:38 PM »
Got given a 202 with Yella Terra head :o, 195 compression on all cylinders ;D. will rip out the old 186 with 173 high compression head (which I spent over $500 getting it totally reconditioned), sell the head, and wack in the new monster motor! YEEHAAA!
« Reply #719 on: December 23, 2009, 08:52:25 PM »
wow cool!!!!!!!!!!!!!!!
