  • Dot Guests: 242
Author Topic: What have you been up to this week  (Read 905676 times)
0 Members and 36 Guests are viewing this topic.
« Reply #950 on: April 12, 2010, 10:36:06 PM »
got stuck in to the pass. door on borrie, but wasn't quite in the mood.....managed to finish all the steel work, but only sanded the outside and ran out of bog...buga
« Reply #951 on: April 12, 2010, 10:42:09 PM »
Kimbo, did you get rarespares rubbers, or spectrum rubbers?
« Reply #952 on: April 12, 2010, 10:47:43 PM »
made a new hinge plate for passengers lower door hinge cut and plated more rust ,maybe hope to prime inner door recess later in the week! Photos tommrow!
Offline jimsvan
« Reply #953 on: April 12, 2010, 11:03:42 PM »
looking forward in seeing those photos
« Reply #954 on: April 13, 2010, 12:51:23 AM »
mastering the art of aluminium welding
« Reply #955 on: April 13, 2010, 01:35:01 AM »
ahhh Marty.. tell us more, I enquired about setting the mig up for Ally but was way too expensive and just not worth it. what kind of welder and set up is required?Danny
« Reply #956 on: April 13, 2010, 10:14:37 AM »
well i hoped to get my mechanic out to finish the mechanicals b4 end of month, yeh right. Water pump started playing up on weekend, needed a new pressure tank for pump, and safty pressure switch for water heater, all up $350, could of spent that on the beddy. No pump no shower, being on acerage we are on tank water so had to fix it now. oh well.
George.
« Reply #957 on: April 13, 2010, 01:10:27 PM »
Marty
How much did the Mig welder cost ?
« Reply #958 on: April 13, 2010, 09:33:56 PM »
measured the difference between early model wishbones and later model wishbone..
turns out the early ones are 3.2mm thick the later are 4.2mm thick.. wow 25% thicker!!!!!!!
keep this in mind people with early vans and v8's in them!! thin wishbones!!
74' is when cfs became late model by the way..
« Reply #959 on: April 13, 2010, 11:22:57 PM »
good work ben, but by wishbones are you meaning lower control arms, or upper control arms?
