  • Dot Guests: 318
Author Topic: What have you been up to this week  (Read 901420 times)
0 Members and 39 Guests are viewing this topic.
« Reply #870 on: March 05, 2010, 05:47:39 PM »
I got a twin speed set up on the old Bedford wiper motor, a switch from repco many years ago, works a treat. Not sure if you can still buy them, switch and relay unit.
« Last Edit: March 05, 2010, 05:53:43 PM by Bas NZ »
« Reply #871 on: March 05, 2010, 07:51:11 PM »
spent the week fitting up all of the little things, rebuilt the grille, fitted the bumpers, fitted all of the lights.
Built up a floor mount shifter for another race car today, basically had to be built from scratch but its come up good. In the process tho, a grinder wheel basically exploded and the cutter wheel got my grandad on the chin, i think it bounced off the bone, but cut thru all of the flesh in the process, VERY lucky it didn't hit him in the neck, or his one remainig eye.
Today we examined the rear drums, touched up the rear doors, and i rewired the fuse box - which worked out perfect as now all of the lights, wipers and indicators work. Also fitted in a new wiper/indicator stalk(HZ)
So its been a busy, sucessful and VERY lucky week
« Reply #872 on: March 06, 2010, 08:07:19 AM »
brought the icecream van home last night! didnt miss a beat what a bueaty.  althou there is a pretty bad ticking noise from the engine i suspect could be a hydrolic lifter colapsed.
Offline Jeff
« Reply #873 on: March 06, 2010, 08:17:11 AM »
One triple cone, choclate dipped,please.
Funny old life.
« Reply #874 on: March 06, 2010, 06:15:01 PM »
I started up the custom van again today, purred like an angry lion :)
i have a few wagons i need/want to get out of the way then back into the van
« Reply #875 on: March 07, 2010, 02:21:58 AM »
we had a long w/end this week.......flat out for two and a half days..... just recovering this w/end...LOL
more in Borries gallery ;D
« Last Edit: March 07, 2010, 02:39:59 AM by Dano »
Offline LS120
« Reply #876 on: March 07, 2010, 07:17:29 AM »
looks good dano..
well things have been a pain int the butt this weekend..
jacked up camper to do the diff change over & found ot that the doner beddy had a holden box in it... ithink its a holden box.
not a bedford so spline is bigger & shorter.. damn.. also the Cresta pinion has a diffrent Oil seal.
oh man so now i've got to do a gearbox swap & try get another seal as the bedford one the lip is facing out & the crester its facing in but the inned rubber seal is the other way around so cant just use bedford for cresta pinion.
i have the box & stuffed motor & drive shaft from donner so is cheap way to go only more stuffing around.
..Jeff.. Get this seal before you do the diff as they are a use once seal you have to munt them to get thaem out. & check you drive shaft length as the cresta diff head is about 1-1.5" longer than bedford. will put up some pics soon
Offline LS120
« Reply #877 on: March 07, 2010, 09:33:48 AM »
well it just gets better...
went to repco & they don't have anything close to the size seal i nead.. :(
tryed ringing Colins Autos in newtown & they are closed down... Damn :(
only thing is to try SKF on monday..  oh well time to remove gear box's & replace while i wait ..
will keep ya informed.
« Reply #878 on: March 07, 2010, 10:56:56 AM »
The guy who ran Collins Autos in Newtown now owns the bearings supplier in Tory Street in town. If you're headed up from Courtney Place it's near the top of Tory Street on the left. Look for the big SKF sign.
Offline LS120
« Reply #879 on: March 07, 2010, 12:17:10 PM »
ok ... have changed my mind again.. going to shorten the drive shaft... as i have a spare box for the one in the camper.
any way here are the pics..
