  • Dot Guests: 293
Author Topic: What have you been up to this week  (Read 891756 times)
0 Members and 24 Guests are viewing this topic.
« Reply #690 on: November 22, 2009, 11:01:50 AM »
Haa  Haa yeah Benny :D Front end seems real heavy for some reason ???
Brett
« Reply #691 on: November 22, 2009, 04:22:23 PM »
I havnt posted anything for ages due to family and work commitments.
But Ive dumped the 253 and trimatic and put in a 308 red with turbo 400. extractors, 650 holley 2nd vac and high tourqe starter. Superformance at capalaba made me up a beautiful set of heads. Port and polished with big valves for unleaded with ls1 springs. new rocker gear. couldnt go rollers due to firewall clearance but should still be a nice cruiser. just waiting for my driveshaft now. next will be some air con for this frign heat. But still beats riding my pushbike everywhere.
All the best to you and yours this christmas. Drive safe.
« Reply #692 on: November 22, 2009, 07:45:11 PM »
cool:)
well the roller rockers that are on my fuely heads (1.6) are still using standard rocker covers.. you can see where they have hit the rocker covers but they work so if you were keen you could go them:)
« Reply #693 on: November 23, 2009, 12:34:41 AM »
Ok, have just about finished the roof , now sanded and P/filler, removed and replaced old t/lights , painted the old rear door hinge mounts/ door jams, fitted painted front grille and F/pan , acid washed/scraped windscreen, removed old mirror mounts, fitted engine cover & sealed, swapped seats out from me shorty, replaed seat belts, trimmed standard Beddie ddash and steering column , finished shifter mount/ assembly. Still to do.......weld up drivers (lwb panel) window,fit dash , fit rear door , sand and hopefully paint roof, fit new mirrors, find other # plate ???..go for test run, and fuel up........woooohhhooooo!!!! :-\
« Reply #694 on: November 23, 2009, 09:47:07 AM »
OOOhhh Danny ...You have been busy eh? ;D
Offline kimbosound
« Reply #695 on: November 23, 2009, 03:21:07 PM »
just cut the front end out under the radiator and hammered straight [wasn't going to as it is all getting cut out after rego but i couldn't stand looking at it all dented and bent] ready to weld back on.....taking the week off to finish the body work and get it into primer. Ordered the RHS for the new tray....[Midalia Steel is having a special MMMMM Maaaaaaaaate] hope to start on that this week as well all going well.
Offline kimbosound
« Reply #696 on: November 24, 2009, 02:22:04 PM »
front end welded back in along with my first ever cut and plate rust repair.....gotta love the MIG......took a couple of goes but i am happy with it.....just gotta smooth it over with some filler....then its wet sand and prime time....yew bewdy.....back on schedule
Offline kimbosound
« Reply #697 on: November 25, 2009, 06:25:00 PM »
truck is wet sanded and ready to mask and prime hopefully tomorrow
« Reply #698 on: December 02, 2009, 01:27:01 AM »
building carport gates.
be good 2 stop all the dust building up on things n keep rain out.
« Last Edit: February 17, 2010, 08:21:05 PM by marty »
« Reply #699 on: December 02, 2009, 08:08:17 AM »
good to see you got your gates finished marty! looks brilliant!
