  • Dot Guests: 292
Author Topic: What have you been up to this week  (Read 891759 times)
0 Members and 24 Guests are viewing this topic.
« Reply #680 on: November 11, 2009, 01:33:43 AM »
that sick Mezzmo , man , now all i have to do is get to the nats to see it, can't wait......
Me not alot really , but sanded front cowl and grillle for borrie ......hopin to finish roof and paint the above this w/ end + fit rear hatch , now i have finally made the spcers needed... ;)
« Reply #681 on: November 11, 2009, 07:46:32 AM »
hey kimbo that bonnet i repaired was the very first bit of cut and welding i had ever done. wasnt very happy with it. i used oxy welding..
Offline kimbosound
« Reply #682 on: November 11, 2009, 09:42:05 AM »
Hey Ben......the front of the bonnet had loads of rust in it.....i cut it out and simply bogged it as it will be coming straight off after rego....i managed to get it a little
straighter and am going to cover the vents with micro mesh that will cover some of your repair that i cant smooth out....will look good when finished.
« Reply #683 on: November 11, 2009, 11:30:48 AM »
yeh it had a big pimple where i weled that yellow section in. the first go i had at it it warped big time!! i then cut out a bigger section of all the warp and tryed to weld that in. well that was better but far from perfect. yeh good idea to chuck the bonnet.
what i didnt do was use a hammer and dolly wich i could have at least banged it down a bit so you could smooth it off with bog. ah well ya learn as ya go ay.
Offline kimbosound
« Reply #684 on: November 11, 2009, 12:12:21 PM »
yeah Ben, it's hard when your not sure....but it's the only way to learn.....the passenger side door that has the peice welded in at the botom came up a treat....i was worried i might
not be able to get it smoothed in so i left it for last.....turned out to be the easiest.....there is allot to do below the front grill but i am not going to worry too much about trying to straighten
it as i will cut most of it out after i get it rego'd and graft the front spoiler in......looks like i am going to have to do some manipulation of the front gaurds to get the flares to fit but no
biggie....i think i am up to the task....if not i will get the panel guys to do it.
Kimbo
Offline grandad
« Reply #685 on: November 12, 2009, 08:58:36 PM »
bugger hit a fence and broke my left hand mirror, so just finshed fitting a set of mini west coasters and dont look to bad but now will hace to make up a door stop for the centre door
« Reply #686 on: November 19, 2009, 09:32:14 AM »
well i fitted a chev 12 bolt to my van yesterday. listened to craig (wa) about angles and so on and man what a difference!!! wound the van up to 150 this morning. dont even notice im going fast cause there is no vibration at all!! so much nicer to drive now .
i came up with a theory that the reason why all my vans in the past have had vibrations are because the diff has been at the wrong angle, mainly because the springs sag and then the diff angle is put out.
Offline kimbosound
« Reply #687 on: November 19, 2009, 09:42:09 AM »
Little done on the truck as i played 4 gigs at The Bridgetown Blues Festival last weekend.....my voice is in rehab
and my fingers are bleeding from playing too much guitar....what an awesome time we had though....got to play
in front of 1000's of people.....now i am away from home again in Bunbury so any planned work for the truck is back on the shelf.
Might get some time on the weekend.....fingers and all other bits crossed.
« Reply #688 on: November 20, 2009, 02:17:24 PM »
Finally got the new radiator in and also just fitted an overflow tank as well . No more wasted coolant ;D :D
« Reply #689 on: November 21, 2009, 07:31:07 PM »
hey john whats coolant? you dont mean concrete do you?
