  • Dot Guests: 268
Author Topic: What have you been up to this week  (Read 885220 times)
0 Members and 28 Guests are viewing this topic.
Offline kimbosound
« Reply #590 on: September 22, 2009, 06:23:03 PM »
Well...the hard work has started on the truck.....tranny is in and now it's on to the bodywork......scary!!!!....more photos in the gallery
http://www.buga.com.au/index.php?option=com_gallery2&Itemid=8&g2_itemId=14197
« Last Edit: September 22, 2009, 06:27:22 PM by kimbosound »
« Reply #591 on: September 22, 2009, 11:26:24 PM »
wow cool!!
« Reply #592 on: September 23, 2009, 06:42:15 PM »
Been a couple of busy weeks in Mezzmo land! Had the baby totally soda blasted now all the body work has been finished. Went round today and the boys have fitted the lift up tailgate, cut in and set the wb taillights, hung all the doors to check gaps etc and had it finished off in high fill.They reckon she'll be in undercoat by the weekend and painted by the 5th or 6th (fingers crossed) - typical, i have to go away for work for 3 weeks on the 9th so wont even get time to play with her "BUGA"
« Reply #593 on: September 23, 2009, 06:58:30 PM »
thats cool, so we can expect pics on about the 7th and 8th?  ;D
« Reply #594 on: September 23, 2009, 07:16:33 PM »
having a wealth of experience with mechanics, panel beaters, painters, auto electricians etc etc i'm pretty close to betting that it still wont be painted when i get back on the 30th of October - always best expect the worst. If its done before i go Edd the pics will be up like lightning!!
« Reply #595 on: September 23, 2009, 07:22:14 PM »
hey bro, if thats the case I'm calling your van "lightning flash" why ...... because you got a flash van and 'the pics will be up like lightning!!"
Offline LS120
« Reply #596 on: September 27, 2009, 11:30:15 AM »
hey guys how do you tell the ratio of a dif again?? so may turns of thr drive shaft to the wheel??
or something like that i think??
Offline LS120
« Reply #598 on: September 27, 2009, 02:26:49 PM »
hi rogue, thanks man i was looking at changing the diff's before the 202 transplant from the old rusty camper but it does about 2.3 shaft turns to 1 tyre so a normal beddy diff  :'(
oh well saves a job  ;D
will fix brakes and put back in as i'm going to make the old chasis into a 1.5 tone traller.
« Reply #599 on: September 27, 2009, 02:59:47 PM »
In case you're interested I'll be going to a Jag diff probably early next year. Wanted to do it sooner but at the rate I'm going early next year is more realistic especially as I have to get this V6 in as soon as possible.
When I do I'll have a diff with Cresta gears in it needing a new home. As you're local it would be an easy pick up.
