  • Dot Guests: 163
Author Topic: What have you been up to this week  (Read 883466 times)
0 Members and 21 Guests are viewing this topic.
« Reply #2210 on: October 13, 2014, 03:33:49 PM »
no oil leaks? that's a bedford trademark isn't it ;)
« Reply #2211 on: October 13, 2014, 07:01:14 PM »
All I can say Dano is crap.
I don't like the look of the oil on the pistons and my guess that it has sat outside for a while- that's why the oil was drained... But that's now history.
My thought is that why shed good money after bad. I'd be cleaning up the bores and making sure there is no gunk in them (the way Busy said), throw on the old head gaskets and the reconed heads and do a compression test.
That way you know what you have. If the compression is all over the place or low, bite the bullet and either recon or throw away and start again.
I would also be questioning the former owner re the honesty of his description and try get some/all $$ back. They knew what they were selling.......
Good luck. Russell
« Reply #2212 on: October 13, 2014, 08:52:46 PM »
Yeah cool Russell, I'll do that.....re old owner.....just gathering my thoughts / info for that one....and yes I'll make the call before I start, because I think I'd rather recond the original motor, and that was the plan but I jumped the gun... buga.
cheers.
« Reply #2213 on: October 13, 2014, 08:59:03 PM »
Sorry to hear of your dilemma Dano.
I think id be taking it back for a refund mate.
How much did they charge you for it?
I bought a little keyhole scope for checking out internal  observations of motor
Bores etc,
They come in real handy sometimes.
C
« Reply #2214 on: October 15, 2014, 11:42:05 PM »
OK   , $1250......
All washed out ok, put some grease at the top of the cylinders to trap any grit around rings, did this several times, wash the grease out, this is what was the result...
cyl 3, surface rust but looks old?
cyl 7 was the oil/water mix......note the ring type mark....  opinions please...what do you think?
dropped the sump to see if the water / diesel had made it's way past the rings - or was in the filter / blown head gasket.... oil filter was suprisingly clean with used but cleanish oil, not black . and no not new....sump oil was same, with reasonably clean sump pan , very thin old oil build up, pick up was clean and again no sign of any h20 or diesel
« Last Edit: October 15, 2014, 11:48:05 PM by Dano »
« Reply #2215 on: October 16, 2014, 04:54:09 AM »
quick emery of the bore, put back together and compression test would be your best move, unless you wanted to do rings and bearings
« Reply #2216 on: October 16, 2014, 06:05:10 AM »
It dosent look too bad.
If your going to keep it.
While your that far id hone each cylinder
and slip new rings n bearings
In her.
How's the cam n lifter bottoms look?
« Last Edit: October 16, 2014, 06:07:39 AM by Marishka »
« Reply #2217 on: October 16, 2014, 11:52:11 AM »
Guess what I got up to last weekend
« Reply #2218 on: October 16, 2014, 01:13:52 PM »
This arvo I met up with Vanwolf who is visiting Auckland. We went for a bit of a cruise along Tamaki Drive in ol' yella and had a good old van chat. Its always great catching up with those who share "the madness"
« Reply #2219 on: October 16, 2014, 11:05:23 PM »
In her.
nice one gentlemen....love ya work.....thats the response i was hoping for ...
what's involved in a hone ...do I have to drop all pistons etc or is it to just to buff the s rust out,
what grit EMERY?  or wet n dry?
not overly keen to drop the pistons ...
Get the heads back tomorrow, want to assemble and fit over the weekend, going to put the SWB crossmember and rims tyres on the lwb   ....mmmwwaaaaahhhaaaa
