  • Dot Guests: 135
Author Topic: What have you been up to this week  (Read 883377 times)
0 Members and 14 Guests are viewing this topic.
« Reply #2010 on: October 05, 2013, 01:55:43 PM »
Thanks Marty, but I'm sure It has been done before. Well that's it for the day, had enough of making doors 2.5 doors to go, a least I am getting faster at making them  ;)
so much for the cheap carport...
« Reply #2011 on: October 05, 2013, 06:23:04 PM »
Looking good Bas !
« Reply #2012 on: October 05, 2013, 07:28:58 PM »
It will look better with the van sitting inside of it.. ;)
« Reply #2013 on: October 07, 2013, 02:54:17 PM »
Well this week I finally realized that the V6 commodore engine conversion to my truck wasn't going to become a reality so decided to sell off the donor car  :(  But have found a suitable replacement to fit into it instead  ;D ;D ;D ;D ::) ::)
OH YEAH BABY !!!!
« Last Edit: October 07, 2013, 02:58:44 PM by John Abbott »
Offline shaginwagin
  • Real Vans are BIG Vans
« Reply #2014 on: October 13, 2013, 07:13:04 PM »
This week Vn brake booster and master cyl fitted  .brake pedal in place...   radiator and air con radiator fitted ( modified the vn radiator surround to sit on Beddie frame.. not difficult just a bit of thought) ;D        picked up modified diff .. Salisbury HX 1 tonner with the heavier axle tubes.  3.36 ratio  12 bolt centre.. has been widened to same as original beddie and now has standard vn disc rear brakes fit straight on   :) :)   will be fitted by mid week so I can order new tail shaft..  all beddie wiring has been removed.  :-\  hope to have all the commodore  wiring loom fitted and hooked in by the end of the week. Tag everything when i took if out of donor car.....    All looking good.....
Julian
« Reply #2015 on: October 13, 2013, 08:54:20 PM »
Talk about go hard or go home "YOU DA MAN"
« Reply #2016 on: October 13, 2013, 09:35:57 PM »
I will be following your build with interest Shagn. I am wanting to do the whole wiring loom thing as well and am hoping it will be a plug and play out come. :-\
If you can get some pics as well that will be good.
« Reply #2017 on: October 14, 2013, 04:53:18 PM »
John,
I think the biggest issue will be that the loom will be too long in some places & too short in others, but there again, I intend to make a new loom from scratch for my tray top rebuild so who is crazier?
« Reply #2018 on: October 14, 2013, 06:15:14 PM »
Looking good Bas
If you put the loom through the top of the firewall (both sides) then you just need to fold up the loom once under the heater.
That's with the main fuse box under the r/h bonnet hinge, and computer on the l/h kick panel.
I think the only wires needing extending a few inches is the coil pack wires if you angle it up some to avoid cutting the floor out.
I used the Calais engine/loom so had a few extras but van runs 99% holden wiring (1% thats not is the tail light plugs)
Offline shaginwagin
« Reply #2019 on: October 14, 2013, 07:48:50 PM »
Thanks Guys ,  I'm going to lay the wiring out on the ground... look at it. ::)  walk around it... ::)  scratch my head... ::)  then just go for it.  IT WILL FIT, I,ve got the full wiring loom., and when i took it out of the donor car I marked everything, so it will be easy to put it back in..  The battery cable to the battery may need to be lengthened not sure yet.     Yes have taken lots of pics, just have to get around to uploading them.    I've used the VN brake booster, master cyl  footbrake mounting bracket but beddie brake pedal.. So no structual changes ( no cutting or welding needed.), so hopefully shouldn't have any problems with engineers  :)  :)
Julian
