  • Dot Guests: 366
Author Topic: What have you been up to this week  (Read 845006 times)
0 Members and 27 Guests are viewing this topic.
« Reply #1950 on: June 25, 2013, 08:32:35 AM »
Well, will be able to finish the Carport come Garage, if the weather stays fine. Need it under cover to work on it over winter, so it can be ready for the Nationals next year.... ???
« Reply #1951 on: June 25, 2013, 08:49:45 AM »
Hey Bas, i like that carport, is it a kit. I am guessing that it is height adjustable looking at the threaded tops of the post, awesome, but what is the little gem you have hidden under that cover. I am running out of space in my workshop so am looking at something secure to build but not costing the earth.
Offline Sundownernz
« Reply #1952 on: June 25, 2013, 10:45:29 AM »
Hey Bas. Nice carport.
The first installment for next years Nationals is out now so flick me an e-mail at gr8van@xtra and i'll send you through the first info sheets. Looks like it could be a good run (as usual).
Garry.
« Reply #1953 on: June 26, 2013, 06:52:17 PM »
Yes George, the basic carport came from a kitset, but it was only 2m high and my Beddie sits on 2.2m being the Jumbo, so had to make up some extension at a mates engineer shop. The carport only sits on 2.8m wide and as I don't have the space to go wider, I am putting a extension out the top on one side with a drop down cover to give me 3.5m wide, the other 2 side will be filled in, the drop down cover will fold back in when not working on the van and seal this side and this will allow me parking room on the side, hard to explain but will post photos as I do more. The height has been taken up to 2.6m as this will allow me to put the van up in the air to work on, when I change the diff over etc.
Cost: I have lost count but not to bad, as I could buy nothing to suit what I needed, as you can see it was a 6 post carport but redesigned one side and took out the post to give me room to work on the van, the only draw back I can see at this stage is when I work on the van I have to turn the van around so the side I'm working on is facing the step out side.
The things we do for our vans, but thought when its finished it's a good place to park the van out of the weather, will also have a roller door if I can find a cheap one.
The little Gem ;D it's had a few upgrades on the body, so must keep it under cover at the moment ;)
Bas
« Last Edit: June 26, 2013, 06:56:39 PM by Bas / NZ »
« Reply #1954 on: June 26, 2013, 06:54:35 PM »
Garry.
Ok, will email you tomorrow. Will be in Oz just before the nationals, and then back to Germany just after, so works out well.
« Reply #1955 on: July 01, 2013, 07:43:13 PM »
I finally finished the windscreen and roof sections, went to drive the van out of the garage for a photo and the starter solenoid decided it wasn't going to play ball, last time I went to drive it (van nationals), it started fine but wouldn't drive, trans pump decided it had had enough.
I knew I had a spare chevy starter so dug it out, tested it and thought sweet. Then I thought, hmm better count the teeth, and sure enough was wrong one. I ripped the solenoid off it and put it on the other one, then I ran out of day, so tomorrow hopefully after I get back from the docs.
Oh and one of my back mag wheels have gone flat, pumped it up, if  it's still up tomorrow I'll get photos from both sides else will just be from the one side :D
« Reply #1956 on: July 02, 2013, 06:20:37 PM »
I took the custom van for a drive today - wahooo
was only up the drive and back but is the first time I have driven it since the project started.
I have an oil, trans and water leak to fix, oh and the brakes need bleeding, but boy does it sound nice :D
Am as happy as pig in mud :D :D
« Reply #1957 on: July 02, 2013, 06:37:09 PM »
Time to get a video happening Busy ;)
Congrats mate, its been a long time coming
« Reply #1958 on: July 02, 2013, 06:42:48 PM »
I thought about a video but I don't really trust the cat with my camera :)
more photos on the website
« Reply #1959 on: July 02, 2013, 06:47:01 PM »
Sounds good Busy,
Id be over the moon 2 mate, its an awsome van.
Love to see a video of it as well.
Cheers marty
